commando1
That trailer is over the top. Nice job, Peter!
Never, ever, tell them what you are really towing.I tried to rent a trailer from Uhaul with my Toyota Tundra Double Cab. They poked in the car and said they didn't have a trailer to pull it as my 69 Fury was too big!!
AGREED! I towed a 78 full size buick home on a uhaul dolly... just for the driveline (wrecked of course, previously built 73? 455). I told them it was an 90 sentra on the contract. My half ton pickups and suburbans have always been listed as three quarter tons...Never, ever, tell them what you are really towing.
BTW, my F150 magically becomes an F250 SuperDuty when punching in the tow vehicle to the computer. Ooops.
With U haul you tell them something smaller, I tell them a Dodge dart of 71 vintage.
A C body fits but tightly I drove over 1200 miles with one on a U haul trailer straight through from Missouri to Jersey, easy ride.
And Stan, you can punch in all the Un truths you want on the home computer. When you arrive to pick it up, they decide weather your wiring is good enough, your hitch is good enough and if your tow vehicle is good enough. If not then you don't get to take the trailer. So enter what they're gonna see factually or you'll be in for a disappointment when you arrive.
I've never encountered that problem the several times I've rented U-Hauls involving two separate locations. Never been turned away.With U haul you tell them something smaller, I tell them a Dodge dart of 71 vintage.
What about some 4-speed pedals? Or was once enough?But... I think my towing days are over anyway....
The truck's work duties mostly consist of mulch or mattress transport for frieds and neighbors now. Can't see any engine blocks rolling around in the bed in my future. AutoZone parts maybe.
An alternator core or dead battery maybe. That's about it. My shoulder and legs are trash now.What about some 4-speed pedals? Or was once enough?
I rented a Uhaul trailer once... and that will be the last time. It was from a Uhaul store too... Not some corner lot. No inspection of anything except the trailer ball size and electrical hookup. This is what it looked like when I got it.Then they must be much more savvy in Jersey. Whenever I get a trailer from there they check the type of truck, year, make and model. They also hook up the wiring and check the ball ratings.
You're not getting out of there without a thorough inspection and it's been more than one location I've rented from, I guess it's 3 now.
... but there definitely won't be any $12 U-Haul moves.
The one " corner lot" I rented from did put a bad trailer on my truck.... I had to take it to a U haul store to swap it out before I left the state. That's when I got the nice new aluminum never used trailer.
Boiled down to them checking out my stuff but not their own
I have wondered about this before... I must have spent ten minutes at least deciding if I could fit one into a 24' box and one on a trailer (not the Imperials) before I decided to check cross country rentals charges... price alone makes a carrier worth it.Formals do squeeze into U-Hauls.
I just went thru my brain cells to come upwith my U-haul rentals.I have wondered about this before... I must have spent ten minutes at least deciding if I could fit one into a 24' box and one on a trailer (not the Imperials) before I decided to check cross country rentals charges... price alone makes a carrier worth it.
NYB's (2)
60-sumthin Power Wagon.
60 sumthin Buick Electra
Early 80's Lincoln
59 Ford.
The Electra was scary. The rear tires were right on the lip at the end of the trailer.
Each were one day rentals, return to same location ( both corner lot stores) and they were all around $55.
