- Joined
- Nov 14, 2010
- Messages
- 28,240
- Reaction score
- 27,591
10 minutes? That's impressive to me, nice job.
Now you have two cars....
The carburation section could be confusing. There's a choice of 1/2/4 which I guess should refer to bbl.s, however one of the two owners seems to refer to the number of carbs with 1 stated.
Thanks for the suggestion.. changed to so it says "1 bbl/2 bbls/4 bbls."
See that, I screwed up already...duh!
Red, I think I can go in to the database and change it... is yours 2 or 4?
It has the 383HP and the original Carter AVS 4 bbl.
All set. It still isn't showing up right in the summary report, so I'll have to figure that out. But I updated your answers in the database, so it will display correctly once I get the report sorted out. (I think it has something to do with the way I changed the response options.)
Thank you, if for some reason it doesn't change and you can delete the posting I can always redo it.
Actually, it would be great if you could redo it. Not (just) because of the problem with the carb answer, but because I added some new questions about the interior. Thanks!
Will do....
Its done...!
Maybe just initials, don't think posting a vin would be a good thing.
