Radiator Compatibility BB 1966-1973
1970FuryConv
Richmond, VA
Saylor, 70Tom, and I were talking with Cold Case Radiator in the vendor forum. Saylor sent him a 1968 BB radiator w/AC. I took a bunch of pics of mine from a 1970 Sport Fury (used for parts). From that, Cold Case concluded they can make a 1966-1970 with correct shroud position. I thought the nothing changed including radiator support, shroud, hose position until 1973. Big John helped out with the possibility of a shroud change in 1971, causing compatibility to change at that year. Does anyone have a Hollander book, so we can confirm that compatibility ends in 1970, if you want correct shroud position?
Can't help, got one that goes from 79 to 89 and the Classic one is only 54 to 66.
I put a Modine "332" in my '70 Monaco, which is what it called for and installed perfectly. In some other radiators I was looking at the other day, that vendor's part number ended in "332", for that same application. The buyers' guide function in RockAuto shows the early year can be '66 or '67, depending upon model, but stops at 1970 models.
