Gerald Morris
Yes.
Griffin,aluminum, three row, OEM.
I suspect THIS is your PROBLEM bro! Try this one: 22″ Mopar BIG BLOCK HD Aluminum Radiator
Yes.
if the back side of the belt turns the water pump, the pump is turning backwards.new serpentine belt set up
And is the serp. driving the pump backwards? There could be a mismatch of parts.What type of water pump did you go with, just a stock replacement or some "high flow" unit? Also the serpentine system does it state if it over/under drives the water pump and alternator?
Bought as a unit; bracket with a/c, power steering pump and alternator and water pump??And is the serp. Driving the pump backwards. There could be a mismatch of parts.
Don't think that could be a problem give it was bought as a unit; bracket with a/c, power steering pump and alternator and water pump??And is the serp. Driving the pump backwards. There could be a mismatch of parts.
Bought an $896 Griffin Radiator which was mis-manufactured, wrong brackets, which because I polished the top, they refused to fix the bracket. Long story except to say STAY AWAY FROM GRIFFIN RADIATOR! They have the customer service of a skunk in a chicken house!I suspect THIS is your PROBLEM bro! Try this one: 22″ Mopar BIG BLOCK HD Aluminum Radiator
and water pump
if the flat side of the belt turns the water pump it spins reverse of the factory pump. reverse pump might require a special housing. easy enough to check.
You are having a large overheating issue so anything in the system, new or old, is suspect.Don't think that could be a problem give it was bought as a unit; bracket with a/c, power steering pump and alternator and water pump??
we actually don't know yet what type of system this is. both types are available with serp. belts. single belt is reverse, multiple belt normal. even if the pump is reverse rotation, the housing accounts for it and the coolant flows normally.I'd thoroughly consider every aspect of a reverse flow system before investing in so much as a bolt toward one.
Seems to me that there would be reverse water pump and/or housing for reverse direction marine engines.if the flat side of the belt turns the water pump it spins reverse of the factory pump. reverse pump might require a special housing. easy enough to check.
i'll ask you this, does the heater core act as a by-pass on his engine? i see that it's an Arizona car. maybe the core's not hooked up but needs to be.Just thinking out loud..
No, I've run a lot of big block Mopars with heater hoses looped or even the outlets plugged and no difference.i'll ask you this, does the heater core act as a by-pass on his engine? i see that it's an Arizona car. maybe the core's not hooked up but needs to be.
that answers the question. thanks.the outlets plugged and no difference.
If Griffin’s radiator proves to be as good as their customer service, I’m screwed!This in NO WAY PRECLUDES it being WRONG FOR YOUR ENGINE!! Of COURSE the vendors will bundle a UNIT, AND SELL IT TO YOU FOR GREATER PROFIT WHICH IS THEIR SOLE MOTIVE!!! Be WARY of LOGICAL FALLACY HERE!
The only design consideration you've shown us regarding this unit is that the vendors wanted customers to buy their product. They made it MORE APPEALING by anticipating the normal difficulties with transforming a V belt accessory system to their serpentine accessory PRODUCT. The vendors DIDN'T CONSIDER THE IMPACT THIS PRODUCT MIGHT HAVE ON YOUR ENGINE OPERATING IN A HOSTILE ENVIRONMENT SUCH AS PHOENIX ARIZONA IN JULY AT RUSH HOUR!
I HOPE I'm WRONG, but you MIGHT have purchased and installed the means to utterly ruin that engine if you're not careful. That Griffin radiator by itself goes a fair way toward that.
Absolutely everything in the system is new. Everything.i'll ask you this, does the heater core act as a by-pass on his engine? i see that it's an Arizona car. maybe the core's not hooked up but needs to be.
No reverse flow, first thing checked.AH, THANK YOU for THAT clarification! Let us pray for the OP that he isn't attempting reverse flow w a street car. I thought about it some yrs ago, but I looked into things, and decided it wasn't right for a family ride.
