mr. fix it
Hi there,
I was told the other day that I had reversed my brake lines at the new dual M/C setup.
I am using a 67 Dual M/C with drums all around.
Currently I plumbed it so the frt res feeds the front brakes & the rear feeds the rear.
I was told that I should have the front reservoir feeding the rear drums and the rear res. feeding the fronts brakes.
I understand that if this was disc/drums then the larger res would feed the front disc's and the smaller res feed the rears.
Again, I have drums all around
Any thoughts to confrim or dispute this?
