Firm feel makes C-body suspension parts. Good guys.
Firmfeel Mopar Suspension and Steering
Hey! Tanks a lot. I did not remember these guys.
Bulb housings grounded???
shooting from the hip here... the cluster bulbs are POWERED? through the rheostat... so remove it and see if it has power available, if you can plug it into the wiring you can see if power makes it through the switch... not uncommon for a copper tab to break on any rheostat switch... Not familiar with the 66, if a separate switch with only 2 wires, you could jump them to see if you complete the circuit... use schematic before jumping anything if more than 2 wires are present.Apparently, the bulbs are grounded through the switch. The bulb housings are a one wire affair and just snap into holes in the plastic dash surround.
as do the corroded, rotten old things we get by with...Thanks, Jeff. Great minds think alike. . .
That looks like a generic switch to me.Have made a lot of progress with the new Navajo and it has become a real joy to drive; however, I have no dash lights and never did since I bought the car. Checked the four dash light bulbs. All appear to be good - including the light above the cigar lighter ash tray. I can't see where any wires are not connected or messed up, so I am suspicious of the headlight switch. I think all the power to the aforementioned lights goes through the headlight switch. I found this switch on Summit's site:
1973 CHRYSLER NEWPORT Standard Motor Products DS165 Standard Motor Headlight and Dash Light Dimmer Switches | Summit Racing
Can anyone validate my trouble shooting and / or tell me if the above switch is correct? Thanx muchly.
Does your car have the separate dimmer switch? It's been decades since I owned a '73 so I don't remember. Those are known to get dirty or worn. They can be rebuilt.
If the bulb housings have only one wire the housings must be grounded by what they are mounted to. Touch a well grounded wire to one of the housings and see if that bulb lights.
I would try replacing the ballast resistor. May not be the problem but it's easy and cheap. The intermittence doesn't sound like a ballast resistor but not starting after a short time does.
Sounds like the same issues I had with a failing coil. Start and run fine when cold but start to sputter then completely fail when warmed up. Both a standard coil and gel filled coil failed when I was running a pertronics unit. Put the points back in and have had flawless running since with a std. coil mounted horizontally per stock.
Long trips often can finish off an already questionable electrical devise. Often had batteries go out after returning from long trips.
Oh, and you were three miles from me when at the A.H. Tech Center. Are the museum cars still downtown in a warehouse?
My money would be on the pickup coil. Had a car ('73 Plymouth) with the same symptoms many years ago.
They seem to be an intermittent failure point.
Look on the set you have... Some include the brass feeler.Thanks, John. I have a pickup coil; if I decide to install it, I'm gonna need a brass feeler gauge to install it correctly. Can't believe after all the years I've been messing with cars / engines that I don't have one. . .
