70bigblockdodge
From a performance standpoint, a standard ignition setup would probably work better.
The lean burn although a novel idea is deeply rooted in emission reduction. The original carburetor is very lean at cruise and idle, WOT is not lean, still targeted for 12.5:1. Your exhaust upgrades make this worse. Advancing your timing will improve the behavior of your engine (to a point), you will have to experiment to see what it likes.
Your lean burn is not a aggressive timing curve (makes for better emissions) modern engines learned to use combustion chamber shape to help and not have to put that much timing in. Anything you can do to put more fuel and timing in, it will respond, again to a point, then it will fall off.
Good luck.
Good luck.
