live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,766
- Reaction score
- 8,976
OK, what do you use this set up for?now on the to do list
You can see exactly where the rotor is compared to the terminal, I mark the housing and get the same result. He can get a better visual with the cut cap though.OK, what do you use this set up for?
I would either change out that air hose, get a new end crimped onto it or Flexzilla has a new end that can be installed. I personally wouldn't trust a hose clamp.here's one for you. about twenty five years ago, that was a piece of 3 in. exhaust tubing with a flat flare. all the years of dropping that impact in it have peened it right around. View attachment 342340 also the 1 in. angle with some torch cut holes for long extensions and pry bars. just welded on to the side of the cart.
the hose was one that was discarded at work. had to be all of six months old when the hose tore behind the crimp. now probably five years old and has served me well at a cost of free. thank you though.change out that air hose
You can twist the tip of those crappyman screwdrivers by hand... I've done it to dozens of 'em. One reason Snapon screwdrivers were a very early purchase in my career. Their tips are hardened and may snap, but a magnet usually pulls the piece out of a still intact screw head vs rounding it to where you need a drill. They also have a bolster on the blade, up by the handle to put a wrench on it... watch out for cheap look a likes... no wrench will fit the cheap bolster, and it won't handle the load if it did.Learned this one today
FWIW, pro's buy tools to break them, and get the job done. Snapon warranty replaces those screwdriver blades, the job gets done, and usually the fastener is in good enough condition to reuse. Bad days when the fastener is destroyed and then you discover that most fasteners are not universal and the local hardware has nothing that will look right and work right to replace it with.
HF replaces screwdrivers too, but the search for replacement fasteners will cost more than a good tool.
For a home user/hobbyist, that's a good call. Sockets and box wrenches will be fine for most folks.I just thought it was a neat trick, one I hadn't though of before. I'm glad I no longer wrench professionally so I don't have to have those spendy tools. My old Craftsman tools turn a bolt or nut just fine for my needs.
