This is
great Leaburn, and thank you!! And for fun, I responded last night immediately upon you saying for us NOT to post until you were done just to piss you off!! LOL!!
Question - while your modification removes a very large amount of the constant high amperage power running through the bulkhead from the engine bay to the ammeter, there are a few high power things that run
BACK to the engine bay THROUGH the nasty old bulkhead
AFTER the ammeter and the welded splice in the dash harness (headlights, AC compressor, etc etc). To make this a true Bulkhead Bypass, can these return power feeds not be run through the firewall as well avoiding the pesky spade connectors in the bulkhead? Maybe using insulated terminal blocks for serviceability? (see below)... would that not reduce the bulkhead overload issue that can exist with those circuits by doing that as well?
Observation: My 66 Monaco has the police style power delivery system which used a bulkhead bypass almost exactly as described, but rather than running an unbroken wire from the starter relay through the firewall to the ammeter, it runs it to a nice insulated terminal block bolted to the firewall, and then through the firewall in its own special hole to the ammeter. In this case the starter relay is on the firewall (rather than the inner fender like your car), and the factory used a fusible link (red with a white stripe) run directly from the relay terminal to the insulated terminal block (upper left just below the hood spring bar), then a new red ammeter feed wire going down to a hole in the firewall with a grommet (you can't see the hole, but you can see the feed wire - it's the vertical red wire). As you stated, they also retain the fusible link from the bulkhead, so you can see the two yellow fusible link plastic identifiers on the starter relay bolt. This allows for some serviceability - see the photo below. In my car this is where the voltage regulator would be, but in some police cases (and I've seen this on Imperials too), the voltage regulator is mounted on a special bracket on the inner fender, and the wiring harness is modified with a jumper wire from an additional terminal block from the regular harness to the regulator on the inner fender. You can see the second terminal block below the red and white fusible link wire.
