Gerald Morris
The bypass takes 50% of the load away from the ammeter gauge, and eliminates any electrical breakdowns should the ammeter shorts out.
All of the car's current flows through the ammeter. No ammeter, no working car, got it?
I am using the Powermaster 90 amp alternator with the underhood ammeter bypass using a heavy gauge wire 8 or 10 if i can remember.
With EFI follow the instructions and if possible use relays for everything.
Your stereo equipment being fed from the battery should be fine. Use heavy gauge wire and appropiate fuses for the amp output. Ultimately, depending on the stereo, having its own deep cycle battery would be best separate from the car battery.
Hope this helps.
Use a battery isolator to charge the deep cycle battery. Even if using dual 12V batteries meant for normal automotive stuff, its best to isolate them electrically, to prevent them discharging into each other when the alternator isn't running, or even if it is.
MANY people FORGET, or never realize that batteries are ALSO RESISTIVE LOADS, and will discharge into other batteries to mutual ruin if not managed. As automotive electrical widgetry becomes more demanding, the need for better battery management also increases. While old fashioned golf carts and forklifts could get by with daisy chained battery banks, its best, even if adding but ONE additional battery, to protect it. I say just buy ONE high capacity battery, even if running a major jamming and rocking amp with the "tooner" for most folks' needs....
