- Joined
- Nov 14, 2010
- Messages
- 28,552
- Reaction score
- 28,404
I don't see why not, I would just protect exhaust manifolds from getting oil on them.
Sheesh, thanks for that reminder I would have totally forgot about that = huge mess.I don't see why not, I would just protect exhaust manifolds from getting oil on them.
My differential cover gasket has been sitting on my bench for a week............I hear you. I have multiple projects going on with my NYB. I'll get them done sooner or later.
Open the commando bar-n-grill, you'll get plenty of visitors,lol.My differential cover gasket has been sitting on my bench for a week............
GET TF Outta here.....NO WAY!?!Working on it.......
Here's the noisy lifter........you'll noticed the bottom is "dished" shape. This is was the culprit...........the rest of them buggers were flat as a board
I can almost guarantee the cause was the result of a top end run...should have taken my foot out of it sooner...the slight tapping sound occurred directly after that event. Never had the problem until then. Checked the push rods on glass table the other day.....all turned out to be dead end straight, no bends in the slightest amount.From what I see, your camshaft along with that lifter are both Junk. You can bet that whatever material is missing from that lifter is also missing from the cam. Cause? Hard to tell. Improper break-in, bad lifter, out of round or to tight lifter bore. One thing for sure is THAT lifter did not rotate.
Yup...intake. I spun it yesterday with just the starter motor.....everything looked kosher....neighbor came over with dial indicator...no loss of lift on the lobe with the damaged lifter. Lady luck be with me......for once?I would agree and would say the affect it will have on performance probably won't be huge or even very noticeable. Was that an intake or exhaust?
just looked, intake. Hopefully the new lifter won't do the same and all you've lost is a little lift on that lobe.
New gears and chain installed last fall.I would of replaced the cam and all the lifters. And the timing gears/chain if it was original.
