So I thought I would dig up this thread from about a year ago as the issue recently happened again, a couple time; once while coming to a stop and the other time at idle. All the electrical was functioning when the car died, so I do not think it is the Fusible Link. It only dies at idle (low RPM). I think it is a fuel delivery issue because it stumbles a bit before it dies, almost like it is starving for fuel. A while back, I had an ignition issue (bad condenser) and it just died. This is different. I checked my Fuel Pump Pushrod and it measures exactly 3.25" so I know it isn't that. Any other ideas? Carb? Issue with the Idle Circuit? Pump? I would think if it were the pump, it wouldn't just act up at low RPM. Filter? Clogged filter not able to pass fuel enough fuel at low RPM?
