First of all, a big thank you to saforwardlook(Steve) for spending the day with me troubleshooting my car. As you may or may not have known, my car has been down since these symptoms started. First, I thought it was fuel so Steve and I rebuilt the carb, I checked the pump pushrod, changed the pump and filter, dropped the sending unit and checked my tank liner. None of these fixed my issue. I decided it's got to be Ignition related. I installed Pertronix and it ran like crap; worse than before. I put the points back in and it ran good but still quit after a couple of minutes idling. I replaced the coil, no change. Today, Steve and I bypassed everything and isolated the Distributor and Coil by running a lead from the (+) side of the Coil to the Battery and started it from the Starter Relay with a screwdriver. It ran great and did not quit. We concluded it had to be something between the Ignition Switch and the Coil. We spent a good part of the day troubleshooting the entire Ignition System to no avail. When I was about to give this boat the Viking Funeral down the driveway, I mentioned to Steve Stan's diagnosis of the Fusible Link. He, like everyone else was of the opinion that they either worked or they were burnt. Being as we tried everything else, we gave it a go. I have a spare Fusible Link but the lead that goes to the Horn Relay is too short so I cannot use it permanently but we were able to use it to test. We connected it at the Starter Relay and at the Bulkhead Connector then jumped the lead to the Horn Relay. It fired right up and did not quit. Finally...it runs!
Stan: Take great pride in telling everyone, me included to suck it and you were right. If only I had taken heed to your diagnosis from the beginning it would have saved me a lot of trouble. Good job sir!
Mike: Check your Fusible Link...LOL!
