carrman
Sounds like you've got some floating ground, and I'd start with making sure the taillights and front turn lights/park lights have good ground.
For symptoms like you're describing the problem is you lost ground or power somewhere. Lots of back feed problems are from power not being present where it is supposed to be. I would start with volt meter checks, preferable back probing connectors while still plugged in. A fused jumper wire would be a quick shade tree way to determine if a circuit was missing ground, but use a very light fuse in case you screw up and short a circuit. It's easier to deal with a blown fuse than a damaged electrical part.GAAAAAHHHHHH!
Sigh. No dash lights. No gauges work, powered ones anyway. The electrical issue is getting worse.
Thought is was the headlight dimmer. Headlights on, hit the dimmer for high beams then hit the dimmer again to drop to lows, no change. WTF? Turn off lights and back on, lows are on. Rinse and repeat. Accidentally hit the turn signal, now headlights flash in time with the turn signal. :/ Replace dimmer, same issue. Screw with dash dimmer wheel as I notice when the lights are on no dash lights but both turn indicators are glowing. WTF?
Turn on the lights, go to high beams hit the switch for lows and all four are still lit up. Move the dash dimmer wheel down to halfway and the high beams go off back to lows. Eh? Turn the wheel back up all the way and repeat. Same outcome. Repeat, this time turn on turn signal and make the lights flash. Move the wheel to half way, lights stop flashing and got back to low beams. Who built this car? Oy.
Then I remind myself the electrical had to have been touched somewhere in it's existence for the siren/bubble and extra equipment.
Now what? The dash dimmer is next to impossible to find. And they aint cheap.
On a good note, went out for another run. Going further everytime. Took my Father in law out for a ride in his dads car for the first time in 20 years or so. He enjoyed it, loud exhaust and all.
Great thoughts guys...Back feeding somewhere. As process of elimination,for what it cost,replace the foot dimmer switch.
Also make sure you have good ground between the steering column and dash.Run a jumper wire as part of the diagnostic.
Underhood,clean the ground for the main headlamp harness that screws to the rad core support (somewhere in front or around the battery).
Check the harness connection of the TS switch at the foot of the column,clean any corrosion and use dielectric grease on EVERY contact.
Find all loose unused wires that pertain to any accessories that were removed from the car when decommissioned.Check them for juice--hot or switched.
Any hot or switched wires laying around still getting juice can wreak havoc.
All bulbs need good ground..Any freshly painted surfaces can cause a bad ground or backfeed.
Hope this helps.
Getting ready for that teething problem soon myself......
Cluster gets grounded as it is screwed into dash frame.Funny you say that. I took the cluster out this afternoon during a break from work. Headlights go from hi to low with no impact form the dash dimmer. Signals still flash faster than normal but I blame that on the missing fender mounted lights and more modern bulbs. Hazard flashers go at normal speed though. Might be just be the turn flasher itself. Now I wanna look at the cluster. I'm thinking of adding a ground or two.
Hazard flashers run on it own flasher unit separate from the turn signals.
Fender mount signals were optional and did not make a difference on the load
Are you running LED's for the park/brake/turn signals?
If so,you need to run this flasher that has an external ground.I usually screw it to one of the bottom of the dash..It is polarity specific so you may have to swap the spades in the car's connector if it does not work the first time out. I have this in the Waygun,and the 66 300 both run LED'S
44890 - 3 Pin Flasher, Variable-Load Electronic LED (Pilot) - Grote Industries
You said you had no gauges?? They get powered up by a 5 volt limiter on the back of the cluster which is fed by the ignition switch.
Since you got the cluster out,test continuity of the 5 volt limiter that feeds the gauges.
Check the switched power wire with test light that feeds the limiter.
If it does not have power with key on test the ignition switch and connector.
Side to side flashing of the flashers could be a throwback to the police light wiring??
