NOThat is something I was not aware of! Is plug easy to get to?
I got to the plug easy but never got it out.
Your experience is not typical. Someone overtightened or cross threaded the plug. I sometimes think most of the work I do on my old cars is fixing something somebody f'ed up in the past.I got to the plug easy but never got it out.
Had the converter on the bench and the plug broke off. I bought a new converter.
Napa just canceled my last order made on 11/24/24. Must be all gone. Bummer.I pump six quarts of this out the dip stick tube every 20k mile on my Dakota. That little truck has been properly abused towing 5 to 10k pounds all over the southeast since 1993. It has 250k miles on it.
Napa has it for $25 a gallon this month, no shipping charge. If it's ordered online for home delivery it must be purchased three gallons at a time. No more no less. Probably for packaging purposes.
I use ATF+4I always thought Dexron III was standard refill. Seems to work good in a couple 727's I have.
In one I put in a small bottle of Lucas trans fix and it took care of some slippage I had going in reverse.
The last time I flushed a transmission, just because it had a ton of miles, I lost reverse, slipping bad. Had no problems before the flush. Afterwards I asked around and heard the same thing from more than one source: You should not flush the fluid, reason because all the by products of all those miles are helping to create friction needed. The fresh clean fluid doesn't perform well in a "worn" transmission. The result is slipping / slippage. I like to keep fluids clean and fresh in my vehicles and machinery. I don't know if there's any merit to the theory or not but I'v never had a auto. trans slip until I changed the fluid. It wasn't a 727 either it was a 2018 chevy v6 trans. I read thru the thread wondering if there would be any mention of that theory, which is what I'm calling it. I don't know jack about transmissions, I know a little about hydraulics and I know enough to run correct, clean oil via quality filter, etc. Has anyone ever heard of the theory "don't change the fluid" aka "clean fluid=slippage w/ high miles"
That may be true, but I've seen it more as "a flush just reveals any problems that may have been previously unknown" - if problems appear right after a flush, it was more than likely that the gearbox was already on its way out and the old fluid was just the duct tape holding everything together.You should not flush the fluid, reason because all the by products of all those miles are helping to create friction needed
