WANTED Two barrel carburetor spacer phenolic/composite
darth_linux
Spokane, WA
I’ve got the old “fuel boils in the float bowl after 15 minutes of hot soak” problem, so I’m looking for a composite or phenolic spacer for my ‘66 383 with two barrel Stromberg. Must match dimensions as illustrated in photo below. Thanks.
Should be the same dimensions as a Rochester 2GC carb, which can come in 1.56" throttle bores and 1.69" throttle bores. Same as the Carter BBD for 383s, too.
Quick Google search for a Rochester 2bbl application yielded Canton Racing Products, 1/2" thick phenolic 85-032 on their eBay store. Looks like it might work with longer studs. Prices vary widely, but all of that should appear on the Google search page. Might call them to verify dimensions.
With that much more build thickness between the carb and intake, might need to straighten out the two bends in the choke rod going to the choke plate. Not a big deal, some normal pliers can so that as needed.
Thanks- I found another spacer listed as fitting "Tri-Power Rochester" 2 bbl carbs for $30. I asked for specific dimensions since they weren't listed. The one from Canton looks to be correct but is almost 50% more expensive . . .
So the gasket I found that was listed as fitting a Stromberg WW is too small. Second time I’ve run into this problem, which is why I’m posting here.
Super easy to make. Take me 30 minutes. You supply the material I can make it for you.
Do you know (or does anyone know) if the 2-bbl stromberg has the same opening and bolt placement as the 2-bbl carter (BBD) for the 318?
It should, but I can probably check later this week. I have both on the shelf.
What I mean is, is the 2-bbl stromberg on the 383 using the same gasket as the 2-bbl carter on the small block. Because there is a thick gasket (almost 1/2 inch thick) for the Carter (small block) BBD's. There apparently is a BBD for the big block, I know nothing about it.
My Newport was sold to me with a BBD from an early 70s Dodge Truck (for some reason) and yes, it's the same bolt pattern.
What I mean is, is the 2-bbl stromberg on the 383 using the same gasket as the 2-bbl carter on the small block. Because there is a thick gasket (almost 1/2 inch thick) for the Carter BBD's.
I had the thick gasket with the BBD, but it was pretty crusty so I didn't use it with the Stromberg I put on. I'll see if I can find a new one. Should of thought of that in the first place .. . . derp!
I didn't make this one from scratch (was just a square spacer when I started) but I did the profiling and o ringing.
As you are adding this take note of any linkages - like choke and throttle - that go from carb to intake/block and make sure they will function as intended with extra distance.
I would go with 1/4" material. Phenolic has very good heat insulation properties. Linkages should not be a problem with only a 1/4" spacer.
Yes, there are 2 different BBDs. Larger one is used on 360 and 383. The 318 carb is notably smaller and different in appearance and I believe it has a smaller mounting pattern.
The smaller BBD version was used on Super Sixes also.
