68PK21 440.6bbl
Why it's important to run your heat riser with a carburetor on the street vs EFI no heat riser.
Or just block it open. Wire or otherwise. Blocking off the ports in the intake are very important. Hot exhaust flows through the base of the intake even when the heat riser valve is open. Some intake gaskets block the passage and many guys block it with a piece of sheet stainless steel.He doesn't directly mention it, but I assume you also remove the riser valve gate from the exhaust manifold and plug the shaft holes. ?
Vapor lock while running or hard start after a hot soak?Seems to be a good argument for keeping a carburetor on our vintage engines. The AVS2 650 I have on my 383 really does work quite well...very snappy performance at all RPM's/load levels and great gas mileage. However, summertime vapor lock issue is present sometimes on 90+ South Carolina summer days with 10% alcohol gas. I'll take the trade-off....simpler system...no electric fuel pump, etc.
Hard start after hot soak...it's never vapor locked while in operation.Vapor lock while running or hard start after a hot soak?
Thanks for the info. You have a fuel problem and not a electrical/starter issue it sounds. The fuel is evaporating in the carb because of the heat. I recommend a small low pressure pump near the tank operated with a fused momentary switch. The next time it acts up, take the air cleaner off and see if you have plenty of accelerator pump squirt.Hard start after hot soak...it's never vapor locked while in operation.
