cbarge
World Famous Barge in a Budget
That is next on the list but gotta finish the Fury's carpet first.how about detailing the "ammeter feed bulkhead bypass" procedure
The reason for a fusible link over a fuse is because the link will take a high current spike for a short time whereas a fuse will blow immediately. If you could find a "slo-blow" fuse it would be closer to what the fusible link provides. IMO, a circuit breaker would provide a better protection than a fuse since they too will take a short term spike in current. I use the fusible link because that is what the Mopar engineers thought was best for the money.May I ask why a fusible link and could you just use a fuse? Thanks for this as I think even I could do this!
I have done this mod, and I really like getting a significant amount of current flow out of the bulkhead connector (and the ammeter). My meter reads "slightly discharged" from the middle marker while everything is working properly under minimal load, and this is the New Normal for that meter (and yes, is slightly annoying). Turn on blower or headlights and the meter shows an alarming amount of discharge, but this is simply the same amount of discharge movement that you would see from the middle marker if you hadn't made this mod. When the car is off, the meter settles back to the middle mark. Also, I used black 10 guage wire so everything looks OEM, and soldered the connections for permanent and perfect conductivity, including the fusible link. I'm not a big fan of large crimps.I have done this numerous times and the ammeter works but reads backwards.
If you didn't run the blower motor off a relay that's another crucial one. I saw a 2 volt drop in the cabin voltage when runningI have done this mod, and really like getting a significant amount of current flow out of the bulkhead connector (and the ammeter). My meter reads "slightly discharged" from the middle marker while everything is working properly under minimal load, and this is the New Normal for that meter (and yes, is slightly annoying). Turn on blower or headlights and the meter shows an alarming amount of discharge, but this is simply the same amount of discharge movement that you would see from the middle marker if you hadn't made this mod. When the car is off, the meter settles back to the middle mark. Also, I used black 10 guage wire so everything looks OEM, and soldered the connections for permanent and perfect conductivity, including the fusible link. I'm not a big fan of large crimps.
I have also powered my AC clutch via a relay (tucked away and invisible under the receiver dryer, all wiring looks normal), powered from the alternator stud and triggered by the pressure switch wiring. This has taken another 5-6 amps out of the bulkhead connector AND doesn't show up on the ammeter, since it's all on the battery side of the electrics and not through the meter anymore.
ac on oem wiring. I ran the high fan position as trigger to relay and got full voltage back in the cabin to the other devices.
