Vacuum hose, another dumb question
ideologist
Bay Area, CA
Where does this little black hose go inside the ca? It is hooked up to the two-pronged vacuum fitting on the intake manifold. Larger hose goes to a brake booster? Not sure where the little one goes, I can't follow it without dismantling most of the dash apparently
Thanks for any guidance!
By chance you have a factory Vacuum gauge? Never seen them on the drivers side usually the pass side for heating/ac controls.
I don't! I bought one to install, and was going to T off of whatever this is.
My car is a factory bench seat with a column shifter, was going to find a way to mount it upside down under the dash because I thought it was nifty
Could be for a trunk release. Does your trunk latch have a little vacuum diaphragm and is there a button in your glove box? My 66 300 has one.
I don't have the trunk release button. Based on where it goes through the firewall, it's probably the heater controls. I never fathomed those buttons used vacuum
