Back to Ohio seems like as good an excuse as any to try Carlisle again...
This time stay away from AAA.
I learned that the first, second and third time. The first time I installed those bolts, I got to do it four times to get it right. Should have gone to the left, I went to the right.By the way:
Torque converter bolts will pull forward when you tighten their buddies. Then, if they’re not almost tight, they’ll pull forward enough to strike the engine block, preventing you from turning the engine to get them down to where you can tighten them.
To alleviate the interference, you must remove the tightened bolts and slide the converter back to make them
Loose bolts clear the engine again.
Moral of the story: align the offset holes, tighten the first one most of the way, rotate to the next one, tighten it most of the way..
..until all four are (almost) snug and in place.
Then you can rotate it around and torque each one.
- dad
By the way:
To alleviate the interference, you must remove the tightened bolts and slide the converter back to make the loose bolts clear the engine again.
Moral of the story: align the offset holes, tighten the first one, back it off a turn, rotate to the next one, tighten it, back it off a turn, rinse, repeat..
- dad
bye bye viper
I'm doing a lot more driving than I previously was. I simply can't justify an $800 gas bill every month. The goat is awesome though. 18,000 mile all original (but slowly changing) car.
Donehey @ horvaths if yall get a chance derete somefin out of your inbox i was tryin to msg you and could not due to your side being full.. stupid technology i blame billy gates
Nice driver, I like those except that the Aussie built LS doesn't seem to share a single thing with the US one... stupid metric system.I'm doing a lot more driving than I previously was. I simply can't justify an $800 gas bill every month. The goat is awesome though. 18,000 mile all original (but slowly changing) car.
Maybe I'm crazy (or simply uninformed) but I thought the LS2 in the gto was sourced from the US. Do you know any specific differences? I know the corvette LS2 has different exhaust manifolds, but other than thatNice driver, I like those except that the Aussie built LS doesn't seem to share a single thing with the US one... stupid metric system.
I thought it was the same also, here's a little light reading for youMaybe I'm crazy (or simply uninformed) but I thought the LS2 in the gto was sourced from the US. Do you know any specific differences? I know the corvette LS2 has different exhaust manifolds, but other than that
P.S. uhoh a gm product is hijacking my thread; please don't ban me
It appears tis I who is poorly informed. In a corner of the building I spent many years avoiding, they do bad things to a small fleet of LS powered cars. I was told on multiple occasions that the GTO was hard to get correct parts for, but I never personally became involved and in truth have avoided that entire generation of GM product.I thought it was the same also, here's a little light reading for you
LS2 Car Engine Specs: Performance, Bore & Stroke, Cylinder Heads, Cam Specs & More - OnAllCylinders
Basic bolt-ons. Heads, cam, headers, midpipes, clutch, etc. First up on the list is new tires and wheels, getting the Ac working, then probably coil overs. Dad may help me make a stone shift knob for it which would be awesome. (He does jewelry as a hobby). Progress will be slow due to my other projects, and this being my daily driver. I may make a thread about it in the off topic section if people would be interested in seeing it.So what the plan for the Goat? Besides driving and enjoying?
