What are you working on today??
Not on the older mechanically injected diesels. I have spoken with more than one person that was dumping the vegetable oil directly in the fuel tank.
On electronic fuel injection pump vehicles, you must do what you describe.
I looked into this as at the time. I had a 1995 GMC turbo diesel C2500 Suburban with electronic fuel injection.
I seen the neighbor pour it directly into the tank and drive away.
Now, he had quite the filtration system in his garage that removed all particles less than X (I can’t remember the number). I also remember seeing him pouring the vegetable oil into buckets through cheesecloth in a funnel.
So, you are correct about the newer electronically fuel injected vehicles.
My plan is to just buy the diesel for this old 300D. I don't think it will be driven enough to get any monetary benefit from anything else.
Avoiding Engine Trouble When Running Vegetable Oil in your Diesel | Engine Problem | MercedesSource.com
There is no such thing as just dumping vegetable oil in the tank and running it.
Used oil needs to go through extensive filtering and if their using virgin vegetable oil the're probably spending as much or more than diesel fuel.
The idea that restaurants will give you the used oil for free is not true as they use and probably get paid for it from the used oil recyclers.
When diesel fuel prices went up several years ago the Diesel Mercedes forums had many threads about running vegetable oil as well as many threads wondering why their cars were running poorly on vegetable oil.
On those forums nobody had put 200k/300k miles on vegetable oil and eventually either sold the car or went back to straight diesel after replacing their injectors and cleaning their fuel tank and everything up to the injectors.
If someone thinks they're going to get the used oil when the restaurant is closed, that is stealing.
I believe the hood opens to 90 degrees for easier access, if you're not already aware of it.
Cut trunk floor out of 65 Fury last weekend.Heading over to donor to drill out about a 100 spot welds today
The winter projects continue on my '68 Chrysler 300. The stock radio was removed and it's in Rhode Island for conversion to modern components USB, Bluetooth, chrome re-polish etc.,which should pair up nicely with power antenna I rebuilt and the new speakers I installed. The radio should be returned back to me in a couple weeks. The rear seats were removed to have them re-dyed to correct a few minor blemishes and scratches. My upholstery guy also repaired the vinyl on the door cards in which the vinyl shrunk above the armrests and pulled away from the stainless trim that surround the 300 medallion. Minor stuff but got the seats and door cards done in one shot.
Today dropped the steering column to install a LED bulb behind the instrument cluster . Just one bulb which is the only one that is impossible to replace from underneath. Chrysler used blue / green lenses to filter the white light. So I thought what it would look like with blue LED for the dash instruments. I am pleased with the results. The orange indicator needles have a fluorescent color. The picture doesn't give it justice and looks better in person. It has a calm, mellow, and modern feel look to it.
Next up is the driver's side power vent window. It works but needs a little persuasion to open and doesn’t close all the way by just a hair. Just enough to get the irritating whistling noise driving at highway speeds.
BLUE looks great!
I bought another $200 Mecedes Benz today from my neighbor. This one is an 84 300SD turbo diesel that was last driven in 2004 and has been sitting outside in the weather since then.
I spent "FOUR HOURS" trashing the car out and vacuuming the trunk, engine leaves/grass and interior. The trash filled a 55-gallon trash bag. The whole bag. About 60 pounds. Didn't wash the outside of the car, to many crusty green barnacles growing, 8-hour job.
But no interior water leaks, no mice, no rust.
After the cursory cleaning that was absolutely necessary to be able to approach the car I put a battery in it, primed the diesel hand pump, ran the glow plugs twice and it fired off the first cylinder in about 10 seconds.
The other four cylinders followed along one at a time in short order. 20 seconds later it was hitting nicely on all 5 cylinders while running on the twenty years old diesel that was left in the tank. At that point the fuel gauge showed 1/8 so I added 5 fresh gallons and let it idle for about an hour.
Goosed it a few times to check turbo function, it functioned.
Good readings on oil, temp and charge. Trans fluid is black but not burned, strange. Goes into gear "very" slow but hooks up solid.
More parts for the 85 300D turbo diesel (the smaller car) will arrive tomorrow. So, I'll play with that one some more tomorrow.
Oh, I don't know Jack about Mecedes, or diesel.
Great find and it sounds like a fantastic vehicle!
I'm trying to wake up a 1985 Mercedes Benz 300D Turbo Diesel, with auto trans, 200K miles, $200. Last started/driven in 2005, parked outside since that time.
Got it from the neighbor on Thursday. Fired the motor off on Friday. Got drive, 4 forward gears and reverse on the jack, and p/s.
I was shocked, shocked I say.
Nice light green mossy patina with barnacles. Interior all present, healthy, and very dirty. No rust. But no shine on the gold paint either.
First impressions? Nice size car, but not a luxury car. Good quality parts that fit well. More parts available than C body parts and they cost less money. Not hard to work on. Very high "routine" maintenance car. But very low incident of repair. Loads of online support groups.
Parts ordered/purchased.
Vacuum pump. Engine driven/lubed. $90, not a bad price.
5 injector nozzles. $35, total.
5 glow plugs. $15, total.
All radiator cooling hoses. $15, total.
All belts. $20, total.
All 6 filters. $18, total.
New master cylinder. $28.
4 rebuilt calipers. $110, total.
All brake pads. $12, total.
All rubber brake hoses. $20, total.
Four quarts Dot-3 brake fluid. $16, total.
Four gallons of green anti-freeze. $28, total.
Battery. $120.
Sixteen quarts of dino 10w40 oil. $60, total. Takes 8 to change the oil with filter.
New working keys from the dealer, $50, total.
Parts shipping, $28, total.
205/75-14 tires mounted/balanced $40. Five-year-old take offs from my 64 New Yorker.
We will see what happens.
I got both of these cars running up and down the road rather well now.
I see them both as novelty cars. Noisy, stinky, and slow. Poor city cars because of turbo lag. A lot of the parts are hard to get to and Benz used to many parts to start with. But the suspensions do work very well, and they are good hwy cars. Also, the seats are very good.
I'm just not feeling the love. So, I will sell both to people that do and take profit.
My 87 Fifth Avenue of similar size and weight rides just as well except for the solid rear axle, it's quieter, handles better, accelerates several times faster, is much easier to work on, and parts cost much less and are more available.
The construction crew has been working on the kitchen and master bath. They got the countertops done and ran out of backsplash tile. That should be finished this coming week.
They also had ordered the incorrect floor tile for the bathroom, which has been rectified.
Tiling should be completed this coming week.
I’m going to correctly relocate the outlets for the dishwasher and garbage disposal, which requires me to contort myself and get into the crawl space, but it’ll be good in the end.
I also have to run a 1/2” pex line from the utility room in the garage to the kitchen, which will require crawling into the breezeway crawl space as well as the existing house crawl space. Yay!
I started working on Colorado Saturday. I hit a deer in November with it. My insurance company totaled it and I bought it back. I bought a hood, bumper, grill and lights from one yard, a fender from another yard, a radiator and condenser from one of my suppliers. I got the radiator and condenser put in, coolant back in, and removed the bumper. I will start putting the rest of it together next week. I had to order the brace from the lower core support to the upper core support w/hood latch, and I found a bad a/c line also
Before
