Unless you've done something to raise the compression ratio, the 100 octane racing fuel isn't needed.
Myself, I run 91 octane ethanol free gas. That seems to work well for my cars. Since I'm in the Finger Lakes, and boating is big here, the ethanol free gas is easy to get and not too crazy for cost.
IMHO, you are better off running the ethanol free gas, but sometimes it's tough to find. I also think that a lot of the horror stories of ethanol laced gas are exaggerated, but that's another discussion.
If ethanol free isn't easily available, I would suggest starting out with the 93 octane and see how it runs. I'm assuming this car is new to you by this question. Once you've got a few miles under your belt, and know how the car behaves, try running some 87 octane if you'd like to. If the car pings excessively, run the 93.
Too much octane won't hurt, but at the same time, it doesn't buy you anything if you don't need it.
Some guys will also mix a little 2 cycle oil in their ethanol mixed gas.
@Ripinator and
@detmatt have been using it for a while and can elaborate more on it than I can.
