i need to replace my 70 300's fuel sending unit - whats the right one -
ive found 2 on ebay -
3/8 or 5/16 pickup
tx
mark
3/8 or 5/16 pickup
tx
mark
1967 GTX and R/T coronet with 440 4bbl engine and the 4 speed manual come with 3/8” fuel lines and senders. I’ve owned 2 of them. Still have one.
1970 440 4 bbl B-bodies with either trans comes with 3/8” supply line, 1/4” return line and a fuel vapor separator. The sending unit has the same size lines. I’ve owned 3 of them, still have one. That’s how they made them.
So this 1970 300 Hurst with the same U code 440 4 bbl engine may just be right in there at 3/8” with the B-bodies.
Do you know what the factory put on the 300 Hurst before the PO added the rubber hose?My 1970 300 Hurst is ALL 5/16, tank to carb. I replaced the entire system (tossing away the PO's lovely rubber hose that ran from the tank to fuel pump to carb! ) using Inline Tube's products.
Thank God for the ignore button, I don't have to be subjected to such stupidity.
Listen to the Brain trust he knows everything.
I don't know I can't see him. Such dumb statements I chose to Iggy.Who dat?
Probably a post that says don't do that with no explain.
