Which power steering box for 67 Chrysler from rockauto?
Wolli
Germany
Hello,
my power steering box has a lot of play in it and needs to be replaced, which brand can you recommend?
I found different qualities at rockauto, but which can I buy? I live in Germany and need shipping to Europe.
Thank you in advance,
Lars
Might look at the Firm Feel website for rebuilt Chrysler gear boxes. Also the Borgeson website, too. I suspect both can ship to you.
You can get new hoses from RockAuto, though.
Ask 10 people about reman stuff and you'll get 10 different answers. The price is right. Cardone didn't build it. They just refurbed it. I'd buy it if I needed it.
Have you tried to adjust the backlash out of it? Is it leaking?
What shape is the pitman arm in? I can't imagine it's in good shape if the steering gear is messed up. A new pitman arm is going to be a lot harder to get, and it's not going to be cheap.
From my observation, the place the gearbox will need adjustment is on the input side, where the rag joint is. If you turn the steering wheel, you'll probably notice the input shaft moving in or out before the car's wheels make any effort to turn from straight.
As to "Cardone", they might not have designed/built the gearbox they are selling, but it is the quality of the reman process that never has really been up to specs. OEM specs that is. I will also add that many reman gearboxes might need a bit of tweaking to get them "right".
Rather than trust a generic reman company, I'd much rather trust somebody like Firm Feel or Steer and Gear that is more MoPar-specific in their products. FWIW EVEN it might cost a bit more.
In the 1980s, my late machine shop associate laughingly associated "Cardone" with "Capone". In the years after that, Cardone seemed to become as big as they came to be by purchasing smaller regional rebuilding companies. Over time, they became the ONE that everybody carried as they were now the ONLY one in that field. BTAIM
On my Chrysler cars, I've had to replace a few idler arms, but no pitman arms. Just my experiences.
"From my observation, the place the gearbox will need adjustment is on the input side, where the rag joint is. If you turn the steering wheel, you'll probably notice the input shaft moving in or out before the car's wheels make any effort to turn from straight."
Correct.
First things first: Did you try to tighten up the adjusting knob on top of the box? Easy to do.
