rapidtrans
Is that what they call "plug-n-play"?
On steroids!Is that what they call "plug-n-play"?
You beat me to it. I was gong to scan mine and pull it into AI and recreate all of them. The only problem is you have to cut and paste each character on the sheet. By the way that looks pretty darn accurate to me.Because I couldn't find the correct font, I made the correct own myself. Works really well!
At least, it's one correct font. It matches my 69 E-Series build sheet. But it seems every plant had their own font every year, because they are all a little different.
Thanks! Always nice to hear that someone likes your workI'm sitting in the bushes on this thread and just shaking my head. You are doing some extraordinary work.
Because I couldn't find the correct font, I made the correct one myself. Works really well!
Have you ever used the form wizard in Acrobat? It maybe a whole lot less work than you think.That's exactly what I did in Illustrator. I've copy/pasted it for Gary to try how it looks. And it looks pretty nice. But I'm goint to buy the "Fontself Maker plugin for Illustrator CC" to make a real otf-font out of it. This Plugin is pretty cool!
My long term plan is to add form fields in InDesign and make the Broadcast sheet a fillable PDF form with the correct font.
I have not. I haven't used Acrobat Pro a lot. I will check out the wizard, thanks!Have you ever used the form wizard in Acrobat? It maybe a whole lot less work than you think.
Please try out the 1970 F-Series Broadcast Sheet as a fillable PDF Form. It's still with the wrong font (a chainprinter font I found online) because I'm still not happy with my selfmade correct font tho.
I think it's a pretty cool feature. You can type in your data and print it to put it in your car and keep the original one safe at home.
Unfortunately the Braodcast Sheets of every model year are defferent. Even the 69 and 70 I made are very defferent due to different available options. And these are both Fusies. So both I have are not useful for you, sorry.Hey Julian! Thanks a lot for all your efforts to put that form together. Do you think it would work for a '66 300 ?
Unfortunately the Braodcast Sheets of every model year are defferent. Even the 69 and 70 I made are very defferent due to different available options. And these are both Fusies. So both I have are not useful for you, sorry.![]()
Does anyone have a '65 Broadcast Sheet template? This is all that is left of mine:
It would be cool to have a reproduction to display.
Sounds like an automated tool to find the foem fields, and that would be very helpful!![]()
If they are close enough it might not take to much effort to make them all once most of the template work is done though.
Good images will be required though.
