- Joined
- Nov 14, 2010
- Messages
- 28,571
- Reaction score
- 28,456
If this were a B-body your engine would be 070 or 071 with ac but I don't know if the engine assembly as a whole would have the same part number for the C-bodies.
I know, I know. I think I was traumatized from having to uninstall my dash and reset it this weekend. Oh well, reminder note written....Slacker!
For the more visual guys on here ;)
Let me help you.
I may have to post up a separate thread asking the question. Its about the only major code needed now.
Yes my number ends in 7 so 077 is it! Thank for that!1970 C body 383-2 with A/C engine assembly 077
Without A/C will be a different number.
R11 would be the standard radio.
I checked my parts catalog and while I could find part numbers for every crazy little thing, I couldn't find a code for the entire engine as an assembly.You need a Parts book from '70 for your answers.
Didn't even enter my mind. Actually that sort of thing seems to happen a lot more lately.You cant ask Doug ?
At least we know what a 318 uses now, thanks again.
At least they were consistent. Here's my 1st page.
Yes it does.Good but does the car have A/C?
Yes it does.
If you have a 1970 build sheet that is intact and it is of a car with 383 2bbl engine, then line two will show E61 like mine. On line four under engine you will have a three digit number, I only know mine ends in 7, I am missing the first two numbers.
Thanks for the offer but we have already worked out the code is 077 for my sheet. Cheers.I have a sharp and clear broadcast sheet for a '70 Dodge Charger...XP29LOG. So, as per the broadcast sheet it is the E61 engine on line 2 and line 4 has "070" under "Engine". Also, it has "31" under "Carb" which is the next field to the right of "Engine".
I can scan it and email it to you if it will help.
I will try to do this.I've not seen a good C body engine assembly chart. Maybe this thread will prompt someone to compile one.
