Looks good.. I did the same conversion in January and have been very happy with it.
Previous owner had just put a dual pot master on it, drum/drum. I put a new stock brake booster on with the conversion and it works good. Eventually I will put a disc/drum master on.Awesome! What master cylinder did u go with?
It does not! Minimum 15" wheelDoes this one allow 14" wheels?
I went with the 4 piston. I wanted to save the $300 bucks and figured the 4piston was already a huge improvement over the drum brakes. Also considering this is going to be a cruiser the 6pistons may be overkill. Just my opinion thoughDid you go with the 4 or 6 piston kit?
I got mine at speedwaymotors.comWhere did you guys purchase your kits?
What diameter and thickness are the rotors?
Kevin
Yes! But I order the drilled and slotted version . Also don't forget the Braided brake linesIs this what you ordered? I'm weighing the option of a kit like this vs. going with a 69-72 setup
I'm not sure a .810 thick rotor is a great idea for cars that crowd 5000 lbs. The factory rotor is 1.25" thick for a reason.
Kevin
