Wilwood drum to disk brake conversion kit
1968fury3sedan
South Florida
Looks good.. I did the same conversion in January and have been very happy with it.
Awesome! What master cylinder did u go with?
Previous owner had just put a dual pot master on it, drum/drum. I put a new stock brake booster on with the conversion and it works good. Eventually I will put a disc/drum master on.
I'm eyeballing their systems too... did you use the powerbrake version or manual? How easy where they to install?
Edit: nvm that question.... might have had one too many beers lol
Is this what you ordered? I'm weighing the option of a kit like this vs. going with a 69-72 setup
I'm not sure a .810 thick rotor is a great idea for cars that crowd 5000 lbs. The factory rotor is 1.25" thick for a reason.
Kevin
For a car that will likely never go over 50mph and will just be a cruiser. I think it will be sufficient and much better than the drums.
