polara71
We had this discussion before. While 70 was the last year there was a carry over into early 71 cars
Just got off of phone with Dorman.
610-121
610-133
610-135
Discontinued.
So, who's wealthy out there.
Why wouldn't you? That was my first thought.Convert to RH
Convert to RH
He needs them now. He can't wait til Carlisle...No they are available
He misinterpreted...Riveted? Your kidding.....?
http://www.sweptline.org/forums/viewtopic.php?f=20&t=21347the lug bolts are swedged (a procedure that is similar to riveting),
Those babies weren't coming out without getting the swedge cut
And even then, maybe not.
what do u mean...curious for you to elaborate.
well partly because I wanted to avoid replacing 10 studs and also because there is something kind of quirky about it that this is a car from 1964. I liked that it was different...even in a small detail as this.
Since I feared converting to RH I found that the rear studs are "riveted" to the drum and will not simply hammer out of the drum...what is the process to remove these?
http://www.crankshaftcoalition.com/wiki/Mopar_tapered_axle_rear_brake_conversion
