Update time!
I'm going big on mechanical repairs like I've said in the first post in this topic.
My plans to get it back on the road in short:
- Drain all fluids, remove petrol tank, remove driveshaft, loosen brakes (so it rolls around easy), remove exhaust and brake loose most nuts and bolts underneath.
- Remove front clip
- Remove engine, transmission and steering gear
- Rebuild front suspension with all new ball joints, bushings etc
- Rebuild steering gear and steering components
- Rebuild the original 383, probably with a hotter cam
- Refresh the TF727, new seals and bearings
- Upgrade front power drum brakes to power disc brakes
- Install steering gear, engine and transmission
- Install front clip
- Rewire engine harness, replace bulkhead connector and rewire parts of the dash
- Rebuild rear axle and bushings
- Refresh rear brakes
- Build H-pipe 2.5" dual exhaust instead of stock single
This should take care of most mechanical parts...
It will be probably more as days go by.
Biggest issues are parts availability in the netherlands. Parts might have a long lead time and are pretty expensive by the time they arrive in the netherlands when tax, import duties, shipping etc are added on the part prices. I can give some examples if people are interested in overseas stuff.
Anyhow, stop the rambling, start working...
I've drained all off the fluids a couple of weeks ago.
And I did some research on identifying the car, engine, options etc.
Cars in the netherlands need an import inspection if they come from another country. Import inspection is pretty strict and I need to have proof that my car is (mostly) original, including original engine etc. I got some help finding everything I need from forum members over here.
(The car is also on jackstands, not just the jack)
Rolled the car outside to clean out the garage first.
And I've taken some pictures with dates for inspection next year to show them that this is what I've started out with.
Build sheet was still there underneath the back couch. Although it's partially eaten by mice...
The shipping number is clearly readable, the VIN isn't anymore unfortunately.
Fender tag is there and has the same shipping order number. Great! One step in the right direction. Datecode A06 is 06 October 1967.
Found the shipping order number underneath the trunk weathering seal after some digging. Again, same shipping order number. Good news! Car looks more and more to be fully original.
Found the engine code next to the distributor.
D383 (D= '68 model year, 383ci)
9 28 2 (Build date 28 September 1967, 2nd shift)
R (Regular fuel, 9.2:1 compression 2bbl engine)
Engine datecode is 8 days before the car was finished and the other info is spot on.
For people who don't know this. You can verify the code next to the distributor with the code stamped on the bottom of the engine.
PT (Powertrain)
383 (engine capacity)
R (Regular fuel, 9.2:1 compression 2bbl engine in this case)
2253 (Day 2253 is Thursday, September 28, 1967 on the 10,000 day calendar)
199x (number of the engine made that day?)
As you can see, the info stamped on the bottom is the same as on top.
Two more pictures because it's possible
