(Pictures are not always loading, sometimes I have to refresh multiple times, do other people have this issue?)
(I also have origin unreachable error when loading
forcbodiesonly.com often)
Well it's been way longer than I planned between updates.
I hope I can be more active again as of now...
Still haven't spoken
@300L unfortunately
Did you end up buying that coronet longroof?
Had a fully rebuild engine and transmission.
Crazy couple of years.
Mid 2021 we were finally able to buy a house with a big shed and lots of room.
I was still working on the chrysler when it became clear that we could move to the house end of september 2021.
I wanted to be able to drive the Chrysler to the new house, so I've quickly finished a lot of things to get it roadworthy and registered.
It passed inspection/registration with flying colors and I've been driving the Chrysler on nice days since sept 2021 and moved it to it's new home under it's own power.
Not a lot changed to the Chrysler in the past couple of years, except that I've installed an LPG system to reduce driving cost significally.
I've noticed that the high gas prices were limiting me in taking the chrysler everywhere on a nice day.
RON98 fuel is around 8.5-9USD per Gallon over here, and LPG is "only" 3USD per Gallon.
Driving the chrysler is even more fun now. The only downside it that the LPG tank takes a lot of room in the boot.
It's a dual fuel system, so I can switch between Gas and LPG when I want.
I can dedicate a post to how the LPG setup in more detail if people are interested.
We've also used the Chrysler to go camping in the German Eifel/Mosel area
Same area as the BBTR event (which unfortunately doesn't include slabsides)
We even got special parking at Phantasialand (theme park) because the Chrysler was too big for the normal spots
The house and shed needed a ton of work, so almost every minute we've had went there for the last couple of years.
The shed was a cow shed, and we've converted it to our car workshop.
In this picture all steel bars, water bowls, equipment was already removed and prepared for concrete pouring.
The concrete floor already there was only 4" thick, so not thick enough for a lift.
We've removed a 10x13ft slab of concrete, dug it out 10" deep and poured reinforced concrete specifically for the lift.
After the floor was poured it was also coated and we've installed an extra wide 6 tonne (metric) lift.
Plenty strong enough for the chrysler and dads Chevy 3100
The shed is fully equipped by now.
Multiple benches, tools/wires/connectors to make wiring harnesses, tire machines, you name it.
Now in 2025 I finally have time again to work on the Chrysler.
I was not really happy with a lot of little things that needed to be finished quick before moving, so I'm going to tackle that.
I'm also redoing/improving a lot of stuff, so a lot of pictures and updates will be coming in the upcoming months
Next post will explain my big plans/improvments!
