I'll throw my two cents in.
My 69 Sport Fury was originally sold in Blythe, CA by Ellison Chrysler Plymouth, my scheduled production date is 5/23/69 and it was registered to the original owners, Albert C Romines and Verba Rowley Romines on June 12 1969, they resided in Blythe, CA so I believe my car was built to CA specs and originally sold to a CA dealer who ordered it for the original CA residents. These pictures are mostly before any work was done and I believe the car was mostly unmolested when I got it.
Gas Tank is a Two Vent Tank, I had electrical tape on the vents.
Mine doesn’t have the California label but it looks like it did at one time and it fell off.
Mine also has this label on the Driver front door jamb.
Engine shots
My car doesn’t show the N95 code in any of the documentation but I have the original temporary registration to prove the provenance of the car.
Broadcast sheet Decode
C Broadcast Copy: Station #-Belvedere
A01 Light Package
007654 Sequence Number: Broadcast Print
A04 Basic Group
523 Friday May 23, 1969
A35 Trailer Towing Package
Scheduled Production Date
B41 Front Brakes: Disc
264475 Vehicle Order Number
B51 Power Brakes
PH Car Line: PLYMOUTH Sport Fury
C16 Console
23 Body Type: 2 Door Hardtop
L Engine: 440 1-4bbl 375hp V8 STD Head Rests: LH/RH AFTER 1/1/1969
9 Model Year: 1969 E-SERIES
C55 Front Seat: Buckets
D Assembly Plant: Belvedere, IL
289850 Assembly Plant Sequential Number STD Carpets
STD Build to Spec's for: U.S.A.
C92 Accessory Floor Mats
Y14 Order Type: Sold Car
F11 Alternator: 50 Amp DUAL PULLEY
F25 Battery: HD 70 Amp RED CAP
E86 Engine: 440 1-4BBL 375hp V8
G11 Glass: All Tinted
D32 Transmission: A727 Torqueflite Auto.
G24 Omit Vent Window
D53 Axle Ratio: 3.23 w/8.75" DIA.
G33 Mirror: Outside LH Remote Chrome
G31 Mirror: Outside RH Manual Chrome
U32 Tires: 8.55x15" Whitewall
H51 Heater: Front w/Air Conditioning
H Trim Grade: High
6 Front Seat: Vinyl Buckets
J11 Glove Box Lock
X Interior: Black
J15 Cigar Lighter
X9 Upper Door Frame Color: Black
V01 Paint Style: Mono-Tone
J25 Wipers: 3-Speed w/Electric Washers
Y4 Roof Paint: Spanish Gold Metallic STD Dual Horns
Y4 Body Paint: Spanish Gold Metallic
V1W Roof Style: White Vinyl Roof
J55 Undercoating w/Hood Pad
V6X Stripes: Body Side Sport-Black
28 B-Body Floor Shift Power Steering
L06 Lamp: Dome/Reading
X9 Steering Column: Black
L11 Light: Glove Box
18 T/Signal Lever
: with N88
L15 Light: Ash Receiver
32 X9 Steering Wheel Type/Color:
L25 Light: Cargo/Trunk
3-Spoke w/Partial Horn Ring/Black
L31 Light: Fender Turn Indicator
29490
37 Radiator Width: 26" MAX COOL
L55 HD Stop Lamp Switch
Yoke
L56 Variable Load T/S Flasher
28632
57 Radiator Inlet Hose: 26" 383/440
L65 Light: Ign. Switch w/Time Delay
28632
46 Radiator Outlet Hose: Std 383/440
L74 Headlamp Switch Light w/Timer
28632
16 Engine Fan: 7-Blade 2½" Pitch
M05 Mouldings: Door Edge
28632
60 Fan Spacer: Thermal Drive
M21 Mouldings: Drip Rail
26429
69 Battery Amp/Series/Caps: 70/27/Red
M25 Mouldings: Body Sill
19440
92 Vac. Fitting: Intake 2-Way
M26 Mouldings: Wheel Lip
919 Engine Assy.: 440 4bbl w/A.T. & A/C
M31 Mouldings: Body Belt
29465
92 Carb.: Carter AVS 4bbl #4640S
M45 Wheelhouse Opening Skirt
28638
45 Choke: Carter AVS 4bbl
M43 Grille Trim Mouldings
2892
093 Trans.: A727 Torqueflite
M85 Bumper Guards: Ft+Rr
25389
31 Speedo. Pinion Teeth/Color: 31/Green
2996
195 Prop/Shaft: #7290/3.25" x 53.64" STD Dual Exhaust System
2931
618 Axle Assy: 3.23:1 S/A 8.75"-10" Drums
23 Road Wheels: 15x6.0" HD Stamped
N51 Max Cooling Pkg.
X9 Wheel Color: Black ALL 5
28817
75 Wheel Cover: Sport w/Hub-15"
N85 Tachometer
27 Frame: B-Body 383+440 V8 AUTO
N88 Auto Speed Control
24626
02 Ft. Sway Bar: .94" Diameter
2269
579 Lt. Torsion Bar: .98" x 44" BROWN
2269
578 Rt. Torsion Bar: .98" x 44" BROWN
R11 Radio: Music Master AM
264 Lt. Rear Spring: Leaf
R31 Rear Seat Speaker: Mono
264 Rt. Rear Spring: Leaf STD Antenna: Telescopic
24621
14 Ft. Shocks: Std. Ride 1” YELLOW
S13 Suspension: H.D. w/Ft. Sway Bar
34006
86 Rr. Shocks: H.D. Ride
39 Front Brake: Power Disc
S77 Power Steering
21 8 Clutch/Brake Pedal: B-Body,D32,B51,N88.
S79 Horn Ring: Lower ½
28998
42 Idle Label: 650RPM in Neut. 5º BTC
34004
79 Tire Label: 8.25-15" MTS 4-Ply Rating
W13 Wheel Covers: Sport
Car Height
W27 Wheels: Trailer Towing Wheel
14 14:00PM Broadcast Print Hour REMARKS:
21 #21 Broadcast Print Seq/Hour
PH23: Plymouth Fury / High / 2 Door Hardtop
L9D: 440 375HP 1-4BBL 8 CYL / 1969 / Belvidere, IL, USA
289850: Sequence number
E86: 440 cid 4 barrel V8 (High Performance) 375hp
D32: Automatic Transmission
Y4: Gold Metallic Exterior Color [Spanish Gold Poly]
H6X: Trim - High, Vinyl Bucket Seats, Black
X9: Black Int. Door Frames
523: Build Date: May 23
264475: Order number
A01: Light Package
A04: Basic (Radio) Group
A35: H .D. Trailer Towing Package
B41: Front Disc Brakes w/Standard 10in RR Drum
C16: Console w/Wood grain Panel
C55: Bucket Seats
G11: Tinted Glass (all)
G31: OS RH Manual Standard Mirror
H51: Air Conditioning with Heater
L31: Hood/Fender Mounted Turn Signals
M25: Wide sill moldings
M31: Belt Moldings
M43: Grille Trim Moldings
M45: Fender Skirts
N88: Auto Speed Control
R11: Radio Solid State AM (2 Watts)
V1W: Full Vinyl Top (White)
Y11: Domestic Publications
26: 26in Radiator
END: End of Sales Codes
