- Joined
- Nov 12, 2010
- Messages
- 3,143
- Reaction score
- 2,960
The final bill (for the paint): OK so if all of us on this forum sent you 5 dollars each would it take 10 football (soccer to us here) stadiums of us to pay off the bill?
11,798 *$5. No, it's not THAT bad ;) But, still, it's the biggest single bill on the entire project now...The final bill (for the paint): OK so if all of us on this forum sent you 5 dollars each would it take 10 football (soccer to us here) stadiums of us to pay off the bill?
In this case, I'm the tree ;)Wow Julian, the apple doesn't fall far from the tree! The camper looks cool, make sure you show us the finished product.
Six figures doing a lot of the work yourself?11,798 *$5. No, it's not THAT bad ;) But, still, it's the biggest single bill on the entire project now...
And lifts the entire investment into 6 figure territory.![]()
... From my cold, dead hands ...Six figures doing a lot of the work yourself?Guess you won't be selling it when it's finished.
We can't wait to see the finished product... From my cold, dead hands ...
They will bury me in it someday!
Probably closer to 14x. New MSRP loaded was probably about 7KIs that about double what the car cost new?
...which would translate into something like $62,000 today through inflation.Probably closer to 14x. New MSRP loaded was probably about 7K
Windshield Wiper Motor: Done
View attachment 47132View attachment 47133View attachment 47134View attachment 47135View attachment 47136View attachment 47137View attachment 47138View attachment 47139
And hey, I dipped the first part of my car ;)
Are the contacts on the switch plate normally closed or open? I repaired all the wiring in mine but I have only one speed and no park. The contact arm was bent. I straightened it but don't know if it should be closed or open before putting it back together again
Ask me...We can't wait to see the finished product![]()
That is what I love doing. Unfortunately, it is more of a curse than a blessing most times. I learned that trying to get someone else, you have to rely on, to match your standards is not fun to do. It will take more time, but I will finish this project in a way I will be proud of eventually!Even if I had the money, I couldn't match the detail I'm seeing here
Some things are priceless.
That's what I'm thinking as well! I will enjoy it as much as I can, and in the end, it's a car and meant to be driven!Now I am driving it as much as I can to depreciate it down.
You will enjoy when its finished.
Boy, that was 10 years ago ;) Please check the FSM, that has a lot of good information on setting the switch plate up correctly!Are the contacts in the switch plate normally clos
Nothing in the 69 FSM but thanksBoy, that was 10 years ago ;) Please check the FSM, that has a lot of good information on setting the switch plate up correctly!
But "I think" they are normally close, yes.
Ah, mentally I was in the headlight door motor, right..!Nothing in the 69 FSM but thanks
Yes. Thanks. Something still not right. Appears I have no cam to move it. I took it loose and ran the motor and manually connecting the points did nothing either even when the switch was turned off. I tested the switch and it's perfect according to FSM but I still have 1 speed and no park. I'm going too order a rebuild kit and try that. I think the gear is the problem.Ah, mentally I was in the headlight door motor, right..!
The switch in the lid of the windshield wiper motor is riveted in place and not adjustable (or not able to get assembled wrong in this case).
If I remember correctly, it is normally closed and pushed open by the cam of the big main gear to stop the motor and then the cam moves the motor into the park position. I discussed that a while ago with @ceebuddy. Maybe he can confirm that.
Also, included in the repair kits Chrysler sold was a bit more information on how to set up the cam in different applications. Maybe that helps with your question?!
