CanCritter
cpl more///
hmmm...look worn...thoughts?
Yes they are garbage
Since it needs a cam, are you going a little bigger?
You dropped a nutwhen I did my full engine resto in 2017 this is what I found after draining the oilpan.
I suspect most of the plastic debris whas used to be sheating of the timingchain-gear
that they used back in the days... I don´t know who came up with such a stupid idea but obviously
the plastic didn´t last long when getting hot from the friction between gear and chain ...
How that screw ended up in there though remains a mystery
thankfully magnet couldn't pick up nada,,,all plastic..timeing gear and valve seals apparently..knew about timeing gear but the valve seal is new to me..anyway plastic thank gawd...heart just dropped when l first saw that ..once l threw magnet in there was relieved...
now where was l...oh ya..dirty…cant have that....View attachment 296428 View attachment 296429 View attachment 296430 View attachment 296431 View attachment 296432 View attachment 296433 View attachment 296434 View attachment 296435 View attachment 296436 View attachment 296437
You dropped a nut![]()
. They were a way to quiet the chain a little more.
...and the cam bearings...time for a new cam and lifter package. I suggest pulling off one of the main caps and checking the bearing surfaces, better to be safe than sorry.
The pieces of black plastic are in fact hardened rubber valve stem seals. They go rock hard from the heat then break up. And yes some of those lifters are worn, time for a new cam and lifter package. Are you going to re-ring the engine? I suggest pulling off one of the main caps and checking the bearing surfaces, better to be safe than sorry. If you see any copper color at all even if they are smooth, time to replace both the main bearings and the big ends. Lastly, pull the oil pump down, check the running surfaces for wear and use a feeler gauge to check the clearances according to the Service Manual specs, or simply put a new pump in as insurance
Remarkable job yer doing, Critter. Looking at the cylinder walls, it appears there is no ridge at the top. Is that true? Also, it appears that all your exhaust valves are burned and should be replaced. The intakes can probably be retained. I've never seen an engine with so much crap in the pan and oil pump pickup. I'll be following this thread. . .
