STEERING KNUCKLE, RIGHT SIDE
What it looked like
Rare Parts 10166. Lower ball joints are hard to find. I think Rare Parts has good quality, but that is based on research.
Steering knuckles: I installed the rubber boots on the bottom of the Moog upper ball joints. I installed the steering knuckles on the upper ball joints., 7/8 long socket, ½ inch ratchet, snug
Steering knuckle, right side:
Lower ball joint, Rare Parts 10166. I installed it on the lower control arm, loose. Then on steering knuckle, loose
Steering knuckle to lower ball joint bolts and nuts: the bolt heads face out. Rear bolt: 15/16 long socket, ½ inch ratchet on nut, 15/16 inch short socket, ½ inch breaker bar on bolt head. ½ inch torque wrench at 120 foot-pounds. Front bolt: 15/16 short socket, ½ inch ratchet on nut, 15/16 long socket, ½ breaker bar on bolt head. ½ inch torque wrench at 120 foot-pounds. Turn both nuts clockwise until cotter pin hole aligns with slots on castle nut. Install cotter pins with wire cutters.
Lower ball joint to lower control arm stud and nut: stud faces up. Nut goes on top. 15/16 inch short socket, ½ inch ratchet. ½ inch torque wrench at 115 foot-pounds. Turn both nuts clockwise until cotter pin hole aligns with slots on castle nut. Install cotter pins with wire cutters.
Upper ball joint to steering knuckle stud and nut: stud faces down. Nut installs from below steering knuckle. 7/8 inch long socket, ½ inch ratchet. ½ inch torque wrench at 125 foot-pounds. Turn both nuts clockwise until cotter pin hole aligns with slots on castle nut. Install cotter pins with wire cutters.
Need to do left side tomorrow. Also order torsion bars, rear boots, and clips from Firm Feel.
Some day soon, I hope to have a roller with rebuilt suspension and working brakes.
