NOT MINE 1973 Dodge Polara Poss police pkg Mesa AZ
Cleaned out the inside and removed the carpet. Got 2 Christmas presents, clean floors and a full build sheet! Just hope i can read it.
It would? I thought 71's started using 8.25 and 9.25?
71 is when you started seeing 8.25s light duty in C bodies, mostly small block furies, but a 73 4 barrel 400 car i would expect to see an 8.75, especially considering its a DK41. Should have 3.23 489 case, maybe even a suregrip.
74 is when you started seeing 8.25 and 9.25 as commonplace in C bodies
On the build sheet under Axle the code is 5 1. Does that tell anything? I'm not good at numbers!
Best of luck with the car… and the clean out, it looks like you got alot of cleaning ahead of you! It would be cool if you could find some history of what department it was in like a police report or some unfilled out tickets or something.
Inside the drivers door in an Arizona State University asset tag. So at some point it belonged to the college. I'm wondering if it was a campus police car? That's only a guess but it's all I got.
With your 73 being a 400, would the gear ratio be 3:21 with the tag, not the common 3:23 in the 8:75, I mean don't the 9:25 and 9:75 look the same , The white books don't have any c body axle codes.
Agree with the 2.76-8-3/4, strange it was not on the tag. 1973 is not my forte but this is the best I can do from the tag-
240-jpg.747693
Y39 special order
F58 heavy service package, rear cross member reinforcement welds
F72 single key package
G11 tinted glass, all
H51 AC & heater
L25 trunk light
R11 AM radio, 2W
EW1 white paint
U ??
F10 ??
F33 left side pillar mounted spotlight, 6-in
F38 roof light reinforcement
F43 reinforcement for pillar mounted spotlight
EW1 white roof?
A1B8 ??
J39 ??
E68 400 high performance
C34 front seat shield
Quite the score for the $!
240-jpg.747693
Y39 special order
H51 AC & heater
L25 trunk light
R11 AM radio, 2W
EW1 white paint
U ??
F10 ??
EW1 white roof?
A1B8 ??
J39 ??
U ?? Built for sale in the US
F10 ?? Police Alternator
EW1 white roof
A1B8 Interior trim code A - A class trim; low level. 1 cloth and vinyl bench seat, B8 dark blue
JB9 inner upper door frames dark blue to match interior
D34 Automatic transmission
EW1 white roof
Excellent, I have D34 being a 904 automatic, didn't think that was possible with the big motor?
D34 on a 73 tag, whether it's a /6 or 440 HP simply means automatic transmission regardless of the actual unit used. We have to look at other documentation to tell us WHICH automatic tranmssion was used.
