Here are the sales codes in lines 8-13.
"" is for descriptions used in 1975 dealership data books.
[] is for descriptions applying to 1974 and/or 1977 info.
No additional markings for descriptions I copied straight from the broadcast sheet.
What I find funny is the absence of an engine block heater (no N25 code). I lived under the impression that N25 was standard on Canadian cars.
YM43T5C138039 broadcast sheet:
Line 8
H Heat - A/C H
53 "Automatic Temperature Control"
C Console - Seats - Belts -Flooring C
58 [50/50 Bench Seat]
92 "Accessory Floor Mats - Color Keyed"
91 [Carpets - Shag]
97 "Trunk Dress-Up"
B Brakes B
11 Front Brakes
31 Rear Brakes
44 [Brakes, Front and Rear Disc (Power)]
Line 9
G Glass - Mirrors G
01 "Defroster - Rear Window - Electric Heat"
11 "Glass, Tinted, All Windows"
41 "Mirror Inside Rearview, Day/Night"
44 "Vanity Mirror - Illuminated"
52 "Mirror Remote Control - Left Outside"
63 "Mirror Remote Control - Right Outside"
F Heavy Duty Fleet F
17 "Alternator, 100 Ampere"
27 "Battery, 500 Ampere Long-Life"
56 [Anti-Freeze 35 Minus]
92 [Thermo Ign Vac Valve]
Line 10
J Miscellaneous J
11 "Lock, Glove Box"
15 "Cigarette Lighter"
22 "Clock, Electric, Digital"
25 "Windshield Wipers, 3 Speed"
31 "Horns, Dual"
41 "Pedal Dress-Up"
52 "Hood Release, Inside"
55 "Undercoating - Includes Hood Silencer Pad"
95 [Insrt/Pnl - Type 5]
L Lights and Switches L
05 [Map/Courtesy Lamp]
11 [Glove Box Lamp]
25 [Trunk Cmpt Lamp]
31 Fender/Hood Turn Lite
35 "Cornering Lights"
41 "Safeguard Sentinel Lighting"
54 Delete Interlock
Line 11
M Mouldings - Exterior Trim M
05 "Door Edge Protectors"
21 "Roof Drip Rail"
25 "Sill - Wide"
26 "Wheel Opening"
31 "Belt"
45 "Rear Wheel Skirts"
51 "Power Sun Roof"
81 [Bumper Guards - Front]
61 [Dome Lamp Sw - Rr/Door]
65 [Ignition Sw Lamp Time Delay]
72 [H/Lamp On Buzzer]
73 "Electric Fuel Pacer System"
74 [H/Lamp Sw/Lite - T/Delay]
76 Signal - Amp. Temp. Fuel
77 Signal Wash Fluid
81 Door Ajar Lamp
Line 12
R Radios R
38 "Radio - AM/FM Stereo w/Search Tuner"
32 [Rear Seat Speakers (Dual)]
48 "Power Antenna"
N Engine Accessories N
38 [Non/Catalytic Exh/Sys]
77 [Aux Vacuum Reservoir]
88 "Automatic Speed Control"
93 [Emissions Export Pkg]
P Power Items P
28 "50/50 Power Seat - Left & Right - 6 Way"
31 "Power Windows"
41 "Power Door Locks"
45 "Power Deck Lid Release"
Line 13
S Suspension - Steering S
02 [HD 1" Frt Shocks]
13 "Heavy Duty Suspension"
25 "Shock Absorbers - Heavy Duty - Front & Rear"
42 "Sway Bar, Front"
54 "Automatic Height Control"
61 "Steering Wheel - Tilt & Tel - w/Rim Blow"
77 "Power Steering"
82 [Str Whl - Tilt - Tilt/Tel]
W Wh./Cov. W
11 [Class I Wheel Covers]
95 [15 x 6.5 Blk Road Wheels]
Y Vehicle Del. And Handling Y
37 Conversion Center
96 [10 Gallons Of Gas]
