65sporty
The manifolds not warped is it Bob?
Passenger manifold has to come back off. I did get another manifold from Gary (Wolfen). The old has to be cracked somewhere.....If you pull the manifold back off, check with a straight edge to see if it's flat. If it's not flat any good machine shop can flatten it. If you get a different one I would still check to see if it's flat and have it machined. I am sure the heads are flat
To get a correct set of 1976 440 exh manifold bolts/studs, I had to order two sets from two other different applications to mix n match correctlyI apologize for not saying that Year One does not have a manifold bolt set for a C-body. I ordered one for a 68-70 B-body that has enough pieces to kind of make it work.
Did you check your new/used manifold to make sure it's flat?
Great!I got the manifold cleaned and on the NYB and fired her up.
1/4 mi test and tune.Great!
SO... . What's left?
