1970FuryConv
Agree!!!If you do not have to pass emissions, I would ditch that system. It is a pressure carburetor. Has very narrow adjustment range. Lots of those old electronics are just going to run out of parts, like the lean burn systems have gone through. IMO I would just make the commitment to change back to carburetor and normal distributor.
Even if you solve your issue with something simple, relay, broken wire, bad ground. How long till a sensor causes a problem, is it available? Did a sensor cause a relay or wire problem? I hate to say bail on the system, but everything earlier than 1996 OBD2 changeover is going obsolete. We are less than 4 models years from 30 years on the OBD2 format. All the OBD2 is multi-port leaving the throttle body setups even further behind, and not really compatible at all.
That engine is a very good piece. Has the swirl/fast burn heads and a factory hydraulic roller. The worst part of performance on that engine is the electronic fuel and ignition castrating it for emissions and fuel compliance.
My 2 cents
Electronics have gotten less and less reliable over the past 3 years. It's only going to get worse.
