EurekaSevven
Hey all,
A few days ago I took a roadtrip to get two parts I needed - an electronic voltage regulator, and more importantly to me, a "301" 4 barrel intake for my 1968 383 engine, which just currently has the factory 2 barrel intake.
Talking to CBODY67 in DMs and doing some reading on this forum and others, it seems some of the linkages need to be replaced for this conversion - as the 4 barrel carburetor's linkage stud is positioned slightly different than the normal 2 barrel. I believe it was the throttle linkage needing to be a little bit longer, and the kickdown rod for the transmission being different - along with the springs (green instead of red, if I remember).
For anyone with experience, is there anything else to consider, and if I listed all of the differences right, how much longer would the throttle linkage need to be compared to the 2 barrel one, along with the kickdown rod (I've heard that the 2bbl kickdown rod can work as well, I have the original "threaded" one from the factory). Anything on the bottom of the trans I need change?
