MoparFlores
I'd put the old carburetor back on. Why did you replace it?
Already tried old carb wont start with it either.
check the thermostat :rant:
What should i be looking for when I check the thermostat?
Nope. Ask Mopar & Missles. He opened that can of worms.You should ask Stan. . .
If you have 1 or 2 dead cylinders it should still start but run like crap. If all 8 cylinders are dead you either have wiped out cam lobes on all 8 cylinders, the timing chain is worn out and the valve timing is way off, blown head gaskets or something more serious. The 318 is a very well built motor and its not unheard of to put 400,000 miles on one if it was well maintained so I doubt that its something serious. It wouldn't hurt to do a compression test, but before you go out and spend the money on a compression tester I would take a second glance over your ignition system. Clean and adjust your points, make sure your plug wires are routed correctly, make sure the negative and positive wires going to your new coil were installed correctly. Mark the location of your distributor then advance it in slight increments crank the motor after each adjustment to see if it will start. If it doesn't start then set the distributor back to its original position. If the valve timing is off only a few degrees it should still run. If your ignition timing is too retarded it will turn over really easy but wont want to start. If the timing is advanced too far the engine will crank very slow when trying to start it.Also check your thermostat.Rotor is turning when I crank it I will take your advice and do a compression check.
I wouldn't jump to conclusions on the timing being too far advanced if the slow cranking was caused by a weak battery.Ok thank you for all of that. It sounds like my timing might be advanced too far because for a good while it was cranking but really slowly, but once I got a new battery and all its firing and immediately shutting off.
Not to trying to muddle the conversation as I agree with every suggestion. Well maybe not the thermostat. We had a similar situation happen after a tune-up on a 64 Chevy 283 a long time ago. When we found the problem we were pissed as we spent 2 days working on it.
The insulation on the wire from the (-) terminal on the coil to the breaker points cracked and was grounding against the underside of the distributor where you couldn't see it. It would crank and almost fire. I've hated distributors that live behind carburetors ever since.
yes finger over spark plug hole will work,you don't have to crank more than a couple revolutions....you can check for fuel by simply pouring about a tablespoon down the carb as some-one cranks...it wont run but should fire a little,be careful not to pour to much,a bunch of fuel with-out firing washes cylinder walls throwing off compression accuracy and will thin your oil that will need changed even if it,s new oil. Just because its a new carb does not mean the float was set correctly not to mention the jets but the the float works a lot like the tank on your toilet...as it fills to a set point it stops filling the tank by closing the inlet valve....if your float is set to high it will fload,to low and it wont respond during acceleration. be careful with pouring fuel as it can back-fire causing fire in carb,smother if this happens...no air means no fire
