Best upgrades for a 2bbl 66 383? I already have a holley 830hp carb. $400 budget on hop-ups not including the carb. I have bo problem tearing apart the motor as its already on the stand.
As mentioned by others,the $400.00 budget is very tight .
I agree with others sell the 830 Holley and get a different carb.
I finished up a side project recently (66 300) that has a 383 using factory cam and pistons.
In short I did a top end rebuild.
Rebuilt 452 heads,Lo-po log manifolds,TTi 2-1/2 system,68-70 factory iron intake manifold with heat cross over blocked. Edelbrock 625 carb,electric choke and 1/2 inch spacer,Pertronix ignition.
The used intake cost me 25.00,used carb 125.00.The 452 heads were already done and were extras from a buddy and was lucky they cost 200.00.
I surpassed your budget by a mile,but my point is it works and works very well with the tame factory cam and pistons.
The 66 4bbl intake is so anemic it sits flat compared to the 68-70 intake which has a rise and is better matched to the 906-452 heads.The 67 and older castings cylinder heads have small valves and do not flow as well as the 452-906 heads.
The open chamber of the 452 heads dropped the compression a wee bit but that is better for todays corn swill they call gasoline and its lower octane quality.
Hope this helps.
