GORDON DREW
What’s everyone using for transmission fluid?? I’ve got people telling me to use ATF+4 or Type F. The pan gasket is leaking so i might as well replace the filter and fluid while i’m at it. Thanks for your help.
So of i go this route, be prepared to drop the pan before the end of the season?On a well used transmission, stick with ATF-3. Atf-4 is a superior fluid, but it is a full synthetic and can break loose a bunch of accumulated crud. Type F provides a firmer shift, but unless you are a hot rodder, you do not need to worry about that on a cruiser. Type F also has a shorter fluid life than ATF -3.
Make sure it's the pan gasket and not the throttle shaft seal. Those seals can get bad and the fluid runs down the side along the pan mimicking a pan leak.The pan gasket is leaking
I'm talking about the throttle shaft seal and not the shifter seals. IIRC, the throttle shaft seal is the same as the later seal, difference being that the later trans has that seal in the valve body (the shifter shaft) while the seal in the cable shift presses into the case. No, it's not the same as the shifter shaft seal on a later trans.The cable shift doesn’t have the same shift seal as a 1966 and up linkage **** TF. No need to remove the valve body on a cable shift to replace O-ring seals.
I had the car up on the hoist before i quit the dealership I was working at. It’s the pan gasket for sure.Make sure it's the pan gasket and not the throttle shaft seal. Those seals can get bad and the fluid runs down the side along the pan mimicking a pan leak.
If it were me, I would think about dropping the valve body and changing that seal. It might be able to be changed with the valve body in place, but I've never looked into that myself. The only issue is adjusting the cables afterward if you dropped the valve body. .
(For those that are going to say about the tool to change the seal in a LATER trans without the cable shift, that's not going to work)
