Anyway, so on to my progress for the weekend. This weekend, I set out to effectively plumb the rest of the car so that I could perform my system checks, and hopefully fire up the system. As I'm sure you all saw in one of my earlier posts, I was indeed successful, and I managed to completely test everything, including my obnoxiously loud train horns (rated at 147.7 dB
). Unfortunately, I had removed my rear axle in order to run the front air lines, so I wasn't able to actually make the car stand up and sit down. Rest assured, everything works.
My first task was to finish up pluming everything up in the trunk, up to the bulkhead fittings. My previous post was from Friday evening, so I was successful in getting it set up. I had to take a break in the early afternoon to pick little one up from daycare that day, so of course, she helped Dad get everything tightened up as should be.
Later that evening I decided that I wanted to work on the control harness that links the Switchspeed ECU to the valve block itself. Because my bags are going to be controlled entirely differently than the "stock" Accuair configuration, the valve controls would need to be reconfigured to my specific setup. That meant cutting up a brand new, untouched, perfectly good wiring harness.
It really wasn't that big of a deal, but for anyone else that's looking to do something similar to what I did, TAKE YOUR TIME! I can't stress this enough. To begin with, I marked their layout up, and I marked my configuration on a different page. This would allow me to effectively say "The signal from 3, controls valve 2", and so on. Basically by writing it down, it gave me a visual of what I was attempting to accomplish. Some may be able to do this without the diagrams (kudos btw), but I myself am a big fan of visual aid.
To start this project off, I cut the main harness, all at different lengths. The reason for the different lengths is because it makes the "bundle" more narrow, and makes it more sleek. While it's not necessary to do this, it's one of my practices, and I like the results. Another reason for doing this, is because I solder ALL of my electrical connections (sometimes leave sharp points). Those sharp points sometimes pierce shrink tubing, and can short across. By offsetting the wires, you have the shrink tube, plus the other wire's original insulation. Again, while this is not necessary, it eliminates the possibility of a loose connection, if you ever need to diagnose an electrical problem down the road. Another thing to consider (pictured below) is color coding your shrink tubing. For my harness below, Yellow are my "down" signals, and blue are my "up" signals. Final step is a layer of electrical tape, and voila, my harness is ready for install.
Next came the task of finishing up my connections to the bags themselves. Prior to running everything in the trunk, I had already run my lines to the front bags (I forgot to take pictures, my bad), so for this one, I needed to finish up the rear bags. The first picture below is from underneath the car, looking towards the front. Next came plumbing my rear bags. I was a little disappointed in my routing of the rear bags, simply because I couldn't make them symmetrical. There's a bracket on the passenger side of the axle tunnel that I can't remove, so I had to route around it, which ended up screwing up my symmetry.
Next I added the tee fittings that would be my sensing lines. Basically all in all, I have 5 sensing lines, 2 for the rear bags, 2 for the front bags and 1 for my main tank pressure. The reason I have so many is because each of my bags is valved individually, and for anyone considering running bags on their setup, I would HIGHLY recommend that you NOT tee your fronts together or your rears together. Basically if you tee them together, there's no roll stability, and the car is scary. With each bag independently valved, they act more like true springs, only with an adjustable spring rate. I can go into better specifics if anyone is curious, but that's kind of the basics.
Anyway, rant over. Next I was on to my train horns. Once again, I started with some rough measurements, and some steel stock I had in the shop, and I started making brackets. They're not very pretty now, but at the moment, I was going more for function, not form. I'll clean them up a bit later, but wanted to get everything mounted so that I could plumb everything. Basically the brackets were as simple as cutting the steel to length, squaring them up in the vice, then smacking them with a hammer to the point that I got the bend I desired.
Next i mounted them up, and started plumbing. I decided to hide them behind the rear wheel well, in between the "frame" rail, and the quarter panel (this is on both sides, 4 horns in total). All in all, I'm pretty happy with where they're mounted, and the installation is pretty clean.
Next I wired it up, and gave it a test. I already posted the video of the function checks of the horns, but I never posted the video of the compressors running. It's honestly kind of anticlimactic, but it's exciting for me in that I'm headed in the right direction.
Next on the list is to reinstall my rear axle, and do a full system check, including making the car stand up and sit.
