67 Fury front suspension rebuild
edbods
Australia
Alrighty, going to try to tackle this one. Practically everything that's rubber and mounted to the stub frame in some way are shot. Main questions I have are, does anyone make poly bushings for the sway bar-strut rod connecting brackets? I'm not going to install poly anywhere else, except maybe the sway bar bushings but that's really it. Everything else will be regular rubber. And are there any special procedures required for removing the strut and torsion rods? Looks like they're going to be a real pain to remove. I saw a post somewhere saying you can smack the lower control arm forward while still in place, with a hammer, and that'll push the torsion bar out the back but don't know if that'll apply for a Fury.
On a semi-related note, the steering box is leaking and I really don't like the numbness so looking very likely that I'll fork out the dough to ship it to Firm Feel and get a stage 2 kit. Stage 3 sounds neat but worried it might be too firm - have seen lots of feedback for A, B and E body owners, but anyone tried stage 3 in a C-body?
www.manciniracing.com used to stock them, you would need to call to see if they are still available.
Poly bushings have little shock absorbtion value and they ten to transmit a lot of shock to the frame. I did a full poly set on a '65 Plymouth fury years ago and the thing rode like a dump truck and squeaked constantly. It did handle better but I sold the car because the squeaking made it unpleasant to drive. Just using poly on the links should not cause issues.
AS for the torsion bar removal: First block both rear wheels, put in park with the parking brake on. Jack the car up, support with jack stands or solid wood blocks and back off the torsion bar tensioning nuts. Remove the links for the front stabilizer from the lower control arms. Remove the retention nuts from the strut rods. You then need to remove the spindle from the lower control arm. Next remove the C-Clip at the rear of the torsion bar, carefully disconnect the bellow seals a the rear of the torsion bars and slide them forward.. Take a chalk and mark the position to the torsion bar in the lower control arm, it is a good idea to reinstall the torsion bar in the same position. Next remove the nut from the lower control arm pivot shaft. Now you can take a solid wood block and a large hammer and knock the lower control arm to the rear, this should disengage the pivot shaft from the cross member. I usually wrap the torsion bar with duct tape prior to removal so the they do not get scratched. To get the torsion bar out of the lower control arm, hold on to the torsion bar and whack the control arm forward with a wood block and they will usually pop right out. Sometimes some spray lube will be needed to assist. Note the condition of the bellows seals at the rear of the torsion bars, if they are suspect replace them. Procedure is discussed in detail in the FSM available for free down load at www.mymopar.com
Thanks, I did pore over the FSM to see if there was anything I missed. I just wasn't sure if there was something else that people experience during this procedure that the FSM doesn't mention etc.
I do know that poly will transfer more vibration, which was why I only wanted it for the sway bar bushings and/or the bushing for the brackets that attach the bar to the strut rods, and nothing else.
Doesn't the LCA sit very snug in the frame? Looking at it from the spindle side, it doesn't seem like it has much room, if any at all, to hammer it back and forth.
Gaining more confidence in doing this myself, I just need to get roughly half a century's worth of crud off the arms.
If you want to feel "numb steering", try ANY Ford product from back then.
"Over-boosted" steering? That was the higher carline GM cars, to me. "Fingertip" steering at its best.
Back then, "steering feel" was about how much of the road was transmitted to the steering wheel. Power steering, naturally filtered a lot of that out, due to the boost levels. With how much the steering wheel resisted being turned in corners being a sensory input many performance enthusiasts allegedly liked, so they could feel how close they were to "loosing it" in a corner.
Toward the later 1960s, some OEMs started to put components into the power steering gears to artificially make the steering a bit harder to turn, perceived to return "feel" back into the power steering systems. Seems like the Europeans led this effort? The alleged KEY to this was a small torsion bar inside the gearbox, whose stiffness determined the "feel", as I understand it.
I was also doing my "learn to drive" education. At that time, our '66 Newport had replaced a '61 BelAir 6cyl sedan. The Newport was our first power steering/power brake car. The faster steering ratio and power steering made it fun to drive. As to "feel", I could tell it was still there, just not as much as the manual steering cars, IF anybody chose to get tuned-in to it.
In our modern times, a lot of people have seemed to forget that a hallmark of ANY car with luxury orientations or aspirations included controls that were easy to operate. In this case, "finger steering" rather than "hand steering". Not unlike "toe-operated" power brakes, which took some getting used, but were fine once you got used to them. I suspect the FF Level 2 calibration might be more akin to what modern power steering feels like, rather than the "as produced" power steering of the 1960s?
Firm Feel doesn't have a way to increase the steering ratio with an existing box do they? Unfortunately for me the RHD cars have mounting holes that don't line up with the LHD steering boxes, so something like a Borgeson box is out of the question. Was hoping to have a faster ratio and tighter steering. It's understandable that these cars were meant to be very easy to drive, but honestly I do like to have a bit of resistance when it comes to steering. I guess it's just what I grew up with.
In other news, I probably should've just blasted the front suspension and steering with the pressure washer from the beginning - spent about an hour or two just chipping away at it and got most of it off before the pressure washer came to mind today, doy. Blasted it all anyway and it has renewed my motivation to fix it all up. The nuts look very easy to access now.
The only thing is, I've got the car on stands but neglected to remove the upper bump stops; the FSM states to remove those while also relieving tension on the adjustment bolt to pull out the torsion bars. Trying to push up the LCA with the floor jack, the arm moves a bit, but then ends up just lifting the entire car while still not having enough room to pull out the upper bump stops, and they have collapsed a decent amount, about as much as the red scribbling in the below pic:
Is it still possible to pull the torsion bars out anyway? Or will it be much more difficult than if I had just removed the bump stops while the car was still sitting on the wheels?
Some thoughts on torsion bar unloading:
1) Try to get the dirt and crud out of the exposed threads if you can. Put some penetrating oil on the bolts and let them soak for a while before even
thinking about touching those bolts.
2) This sounds dumb but be sure that you are unloading the torsion bars with the vehicle supported on jackstands, and NO vehicle weight on the suspension.
Safety here is #1.
3) Once you remove the load on the torsion bars, you will be able to lift the suspension to get that upper control arm rebound bushing out.
4) Use the torsion bar removal tool available from Mancini Racing to remove the bars. The tool works like a champ, and does not mar the torsion bars.
Well worth the 50 bucks or so plus shipping.
Linky here: Mancini Racing Torsion Bar Remover/Installer
This is how I handled my torsion bar removal, and the job was painless, as was re-installation.
Also, lots of people want to ignore that lower control arm bushing, because it can be tricky to remove. That guy is not too bad to remove and replace, and well worth the effort.
Lastly, if you opt to go with rubber for everything, contact Craig@mobileparts. He hooked me up with EVERYTHING!
Oh yeah I definitely made sure that the stands were on the frame and not the suspension. I blasted the **** out of ALL threads with the pressure washer on the laser setting. Very clean and ripe for an overnight soaking with some ATF which works really well as a penetrant...50/50 acetone/ATF mix thins it out and lets it creep better. Some say it's better than actual penetrants.
I'll try unloading the torsion bars, I didn't do that because unfortunately for me, the first step was to remove the bumpers and of course I skipped that and went straight to jacking the car up lol.
I definitely want to replace all the suspension bushings, it wanders all over the road. As mentioned before, I was interested in poly bushings for only the sway bar brackets that attach it to the strut rods, but since those seem to not be available anywhere I've settled for regular rubbers.
I think I won't use the tool enough to justify forking out a hundred bucks for it. Have seen others recommend tapping the LCA with a hammer to pop the torsion bar out so I'll try that.
As to steering effort and "feel", the physical mechanical ratio in the gearbox is pretty much what it is, unlike the similar GM800 gearbox which has all kinds of constant or variable ratios and firmness calibrations from the factory. PLUS the aftermarket items which make it the darling of the circle/dirt track racers.
NOW, the "effective" ratio CAN be quickened with nothing more than a smaller diameter steering wheel. Decreasing the "lever arm" should also increase the effort required to turn it at the same time. Something like the aftermarket version of the Dodge "TUFF" steering wheel, maybe? OR something else that Grant makes?
You can also max-out the caster settings on the front end alignment adjustments. Increasing the physical effort to turn the car as the self-centering action is increased at the same time.
Which is why the OEM front end alignment specs for manual steer cars were always "negative caster" as the power steering cars were "positive caster".
Getting a tighter turning radius probably cannot be achieved. Chryslers, being "rear steer cars" have a more accurate Ackerman angles than a "front steer" car. Which might also explain the slightly larger turning diameter they tend to have. I kind of suspect there is only a certain amount of degrees the wheels can turn before the Ackerman angles get out of whack, compared to the amount of travel available in the linkage?
One other "little trick" I came up with in the later 1960s, is that front tire pressures need to be 2psi higher than the rear pressures on normal (non-Corvette) rwd cars. The basic pressures would be 28psi for the rear and 30psi for the front. This results in the relative weight capacity (at the pressures noted) being approximately equal, front to rear, for the weight being supported AND the possibility of driving 75mph or faster (which is where the 28psi comes in, per the 1970 Dodge Polara/Monaco owner's manual).
At those pressures, the treads wear "flat" on the stock 5.5" wide rims. No "center wear" from too much air and no "edge wear" due to not enough air. Should be the same for 6" wide wheels, too. Something to start with and then see if things work as they should.
Perhaps these things might help you get a bit closer to the "steering feel" goals and desires you have.
Not really concerned about the turning circle, it's a boat after all...comes with the territory. But great food for thought in the rest of your post
Sorry if someone already mentioned this. Once everything was unbolted, I was able to free the torsion bar by giving a good whack to the front side of the lower control arm right on the nut that secures it to the K member. Everything moved backwards and came apart (LCA and torsion bar, that is) without difficulty.
Are you talking about the adjusting nut? Or where the torsion bar actually goes through it? Maybe I'm missing something but the only attaching points are where the torsion bar sits, and where it connects to the spindle. Never mind - saw a video and there's a nut and stud on the inboard side of the control arm that holds it in.
I did see that, don't have easy access to a machine shop so I might try hammering the arm to break the torsion bar loose.
If you remove the tension on the t-bar adjusters, the control arms may move farther with the jack. Just a thought. Lindsay
Woohoo, it's been frigging hot so I've settled for just chipping away at this entire thing bit by bit each day. Slowly but surely. Completely loosened the adjusters and I was able to lift the upper arm to have plenty of room to take out the bump stops. Left one had some cracking but was still intact...might be the original. Numbers matching! Lol. Right one was already collapsed in on itself, and the rubber basically flew apart when I used an electric ratchet to loosen the nut and it started spinning.
The left torsion adjuster was incredibly difficult to loosen, not sure why. Shot it with some penetrating oil but didn't seem to do much. I had to slip my floor jack handle over my cheater bar to make it 3 ft long to loosen it without exhausting myself, and even then, it was so tight that I was worrying all the way through that I might snap or twist that bolt off. But it's a seriously fat bolt and it held. The right adjuster was pretty easy, only taking a 1/2" ratchet. I suspect the years of the power steering box leaking all over it may have done me a favour in that regard.
Firm Feel has quite a bit of a wait for steering boxes, but if you get your current one rebuilt, it might be a shorter wait. I just got one for my '67 VIP from Steer & Gear -- they shipped it out within a couple of days. I got the "modern feel" one and it's like a night and day difference from what the steering was like before; no more slop and more direct, while not being too firm.
Hi People,
Many Years Ago i Used to Work in Army Maintenance. At One Stage We Were Replacing the Suspension Rubbers on the Ten & 15 Ton Trailers.
What We Eventually Found Was That the So-Called Wonder Bushes Caused the Control Arms to Crack Badly.
As Mentioned Above, They Ride Rough, They Squeak Like a Dunny Door, They Transfer All the Impact to the Frame and are Just an All round P.I.T.B.
You Might Have to Replace the OEM More Often But You'll Curse the Day You Fitted the Others.
I Have Loved the Power Steering on the C Bod's All My Life.
One Finger Parking is What Owning a Chrysler is All About.
In All My Years of Ownership (Close to Sixty) I Have Never Felt any Problem on the Road with Chrysler P/Steer.
I'm About to Make a Statement That Might Upset a Few People But It is My Opinion That Under Steer / Over Steer
is a Challenge That Most Competent Drivers Take in Their Stride.
( Ive Held a Heavy Rigid Licence for Over 40 Years So I Can Speak From Experience.)
My $2.02Cents Worth.
Regards Tony.M
I'm fully aware of the squeaking and vibration transmission that poly bushings have, which is why I only wanted to use them where the sway bar bolts to the strut rod. Although that might also be a bad spot to put them, so I'm happy to settle with just replacing the square bushings where the sway bar connects to the stub frame.
Been tackling this bit by bit, day by day. Will be documenting info that will hopefully be of use to anyone in the future that stumbles across my posts.
Strut rods finally came out, I took off the front nuts first before tackling the rears, fronts needed a 24mm socket, while the rears needed a 19mm. I tried to use a pipe wrench to hold down the strut rod, but wasn't able to get it to bite so I held the rod as tightly as I could with one hand, and rattle gunned the stuck nut back and forth until it came out. I think putting them back in will be easier - the rods didn't seem to spin when tightening the nut, only loosening. But going back and forth helped clean off the dirt/rust on the threads so kept doing that until the nut eventually came off.
I think the steering box leaking helped keep things loose on the right side, it was fairly easy to loosen everything on that side, while the left was a real bear. For aussies: there's a site called Hemi Performance that sells inner tie rods for 65-68 dodge phoenixes - unfortunately, while the shape and length are almost exactly the same, the ball joint stud on it is just slightly too small, and won't press fit into the steering arm. They are Moog ES713s which you can buy off Rockauto for much cheaper.
Unfortunately, the left strut rod is slightly bent, thankfully, someone in my city has a used one. Is it recommended to replace strut rods in pairs or can I just swap the bent one and send it?
Aww yisssssss, got the upper ball joints replaced. Forget trying to do it by hand - a 6 ft cheater bar didn't make it budge one hair, and forget trying to tighten it by hand while it's on the car, it's doable, but you'll wish you had a vise on a bench, or a BIG impact. At work, one of the guys in the workshop had a big fat 18V high torque impact and it took it right off, but you could see it was still putting up a fight. The arm got rather warm too. I later looked up the specs of that cordless impact he had...2100 N m, or 1500 ft lb...took at least 10 secs of this per joint. But man was it satisfying. I think the socket actually gouged out the flange/lip that the ball joint bottomed out on during this, because I had to remove the new one on one of the arms to grind it flat again.
Tightening by hand would've taken too long so I just threaded the joints in by hand as far as I could go, then zipped it all the way down with the impact before finishing with the torque wrench.
Now it's the lower control arms, steering box and rag joint, and rear suspension bushings...
Fun with a 20 tonne press:
I tried to use a piece of galvanised pipe, but the widest size bunnings sells is 25mm - this is too narrow to fit around the pivot shaft once that's been pressed into the bushing, so don't bother going there. They do sell 30mm pieces, but they're at least a metre long and unless you want it for other purposes and happy to cut it up, don't bother. I was VERY lucky that near the press were some very chonky sleeves that barely covered the bushing flanges.
Upper bushings replaced! Press and puller kit made short work of them. Actually kinda fun pressing them in and out. When pressing them out I had to use a stack of washers to make sure the sleeve wasn't lopsided.
The entire front suspension is now ready to go back in which concludes this saga, but before I do that...STEERING BOX! Time to loosen the lines and get ready for a whole mess of power steering fluid.
