And Another Thing....! Suspension Adjuster Bolt Source
That would be cool, thank you.
I noticed that your site lists tie rod parts for my '67 Imperial, but it doesn't list adjusters. Is it accurate to deduce that the Imperial adjusters are different and you don't carry them?
Now by adjusters to you mean the torsion bare adjusters or adjusting sleeves for the tie rod ends ?
Thanks
James
I mean the ride height adjusters.
Here's what I was getting at: When I put in 1967 Imperial into your parts finder, I see parts that are listed as fitting for the tie rod ends (inner and outer), as well as the adjusting sleeves. So I'm assuming these are either common to other C-Bodies or you just have the Imperial-only part.
However, I don't see a torsion-bar adjuster for the 67 Imperial, but I do see it for the C-Body. So I'm inferring from this that the adjusters are different on the Imperial, and you don't carry them. I recognize that I may be reading too much into the completeness of your online catalog.
Here is one of the adjusters: The block is 2 1/4" long, 1 1/4" wide and 3/4" thick. Stud portion (not including the head of the bolt) of the bolt is 3 1/2" long. The bolt is a 9/16 diameter.
Thanks
James
Yes in rubber $17 or polygraphite $25.
Thanks
James
