The windshield wipers on my New Yorker have stopped working completely. They’ve never worked right; the best I’d get since I’ve owned the car would be a couple of cycles before they would stop wiping, although the motor would continue to make the odd groan or knock.
In a related issue, the reverse lights would sometimes work, but most often wouldn’t. When they would work, they tended to flicker a bit and then go out.
I decided to try and fix the wipers, as I’ve been stuck driving it to work only when the weather calls for clear skies.
Looking at the wiring diagram, I discovered the windshield wiper switch and the backup lamp switch are wired together. I figured I’d pull the wiper switch to inspect it and clean it, hoping I might be able to find or correct the wiper and the reverse light faults. After pulling, cleaning, and inspecting the switch, I didn’t find anything obviously damaged or out of place. The switch and wiring seemed in pretty good condition.
I should note, it’s the rheostat-equipped switch (is this the “3-speed” switch vs. the “2-speed” switch? I’m not sure…), and an automatic transmission with the reverse light switch on the column.
My situation is this:
The wiper switch B terminal and the B/U (? - terminal that connects to the B1 circuit white wire that runs to the backup switch) terminal ‘ohm out’ with no resistance between the terminals through the switch, no matter which position the switch is in.
I get 12 volts (ok, about 11.4-ish) at the pink V1 wire that plugs into terminal B on the back of the switch. I get the same voltage at the B terminal blade when the V1 wire is plugged in.
I don’t get any voltage at the B/U terminal when there is voltage present at the B terminal.
My question is:
What is the likely cause of not finding any voltage at the B/U terminal, if there is voltage present at the B terminal, and the B - B/U terminals ohm out?
Is the voltage likely grounding out somewhere in the switch itself? How would I test this?
If anyone has come across something like this, or has dealt with a similar issue and can provide any guidance, I’d appreciate it.
(I’ll see if I can get some pictures up later today….pictures always help, I believe)
My question is:
