70bigblockdodge
Yes, if you were to measure the chambers and down in the hole you would be lucky to get to 9:1, putting open chambers on that will put it in the 8:1 which will hurt throttle response and make the car not as pleasurable to drive. Cylinder #3 as stated above came up at 125# that's not great. He is at sea level and 9×14.7= 132.3. Add in another .020 for composition head gaskets over the steel shims in there now and will be lucky to stay in the high 8s. I think going to a ~10cc bigger open chamber With a small bore and short stroke 383 will not be great, and his is supposed to be a HP.Will, for your use, I can't see worrying about CR's. Keep it so it uses regular octane gas. 9.0 would be my choice. It will be simpler to tune.
Just my thoughts, also the later heads do not look like the original 516 which has no end core plugs.
