Sixpactogo
All the different angles will drive you nuts. Cass at Dr Diff. told me the easiest way was to forget about the driveshaft angle. Put a digital angle finder on the flywheel pulley. Write down that angle. Drop the drive shaft and put a 5/8" long barrel socket in the U cups of the Pinion and write down that angle. If you have leaf springs you have to consider 2-4 degrees of axle windup. That said, if you have your pinion angle down a couple degrees from the front pulley angle, you should be in the ballpark. Driveshaft angle does not even need to be considered. IMO, your first angle measurement are in the ballpark. Your issue (as others have mentioned) is in your drive shaft itself. That dent in post #9 concerns me the most. I would have it re-tubed and balanced by a reputable shop. Bet that takes care of your tremble @ 80.
