68plymouth383
Good to see you back on Man!!
Did you get the plates yet? Very interested in this low buck approach.The brackets can go either way - front or back since the spindle holes are symmetric. In my case I have found that I get better caliper/spindle clearance if they go to the front. Also, the Camaro rotors are one piece design and are 2" wider/thicker - they will not fit. More than likely the rotors are 95 Mustang. I used 97 Nissan Maxima rotors because I think it is a better fit in my case - it is slightly thicker and the caliper lines up with the bracket perfectly.
However I learned that my setup will clear the stock steel wheel with 5/16 spacer only. Mustang rotor diameter .15" smaller and and overall thickness is .13" less. I did some 3D modeling and it will not clear the stock wheel too. So I am a bit confused... Saylor, what wheels do you have?
The only thing that ECI could have done is to move the hub flange out (custom hubs) so they could use deeper rotor and clear the stock wheel. But that means the wheel will be sticking out a bit more that factory, let`s say 0.5".
Anyway, before laser cutting the brackets I decided to make a test bracket out of plywood and put everything together.
View attachment 46447View attachment 46448
I will mock up the suspension parts tomorrow to see how everything fits.
The local metal fab. shop quoted me $75 for two brackets. So far I have spent around $100. Should be under $200 when everything done.
This is exactly why I will not consider any of these "conversion kits".I am really curious if their kit would clear the stock 14" wheels?
I had to weld and re-drill one of the bracket mounting holes last night (missed it by 1/8" in my blueprints) and after all was done put everything together on the bench tried to fit the stock rim with 5/16 spacer and it would not clear (need 1/2" spacer). Centerline rim fits fine.
I believe in keeping it Mopar.
